configuration tool question
Hi there is a tool where you can assambly a device, I mean put the IOS and check if all the components I want are compatibles.
Can somebody help to find out this tool. Is free but I can not locate it.
are you referring to the Network Assistant ? Check this link:
Cisco Network Assistant
http://www.cisco.com/en/US/products/ps5931/
Or the Online Configuration Tool:
Cisco Dynamic Configuration Tool
http://www.cisco.com/appcontent/apollo/configureHomeGuest.html
HTH,
GP
