Configure 2 links load balancing using BGP
Tharaka4747
I want a sipmle configuration regarding to configure load balancing using BGP for two links. My netwrok topology is as below.
So anyone have simple BGP load balancing configuration for this kind of network topology, please share with me .
5 Replies 5
John Blakley
Here you go:
http://www.cisco.com/en/US/tech/tk365/technologies_configuration_example09186a00800945bf.shtml#conf2
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
Abzal
Level 7
Level 7
I think BGP maximum-path it's solution what are looking for which by default is 1. Change to 2 then it should be ok. ISPs should be advertising default routes.
Configuration:
router bgp ZZZ
neighbor x.x.x.x remote-as 4700
neighbor y.y.y.y remote-as 4700
maximum-paths 2
Verify:
sh ip route
The link
Hope it will help.
Best regards,
Abzal
this will install multiple BGP routes for the same prefix in the RIB but the load-sharing will still be taken in charge by the switching process which is CEF by default and the traffic will be load shared by src-dst IP.
Regards.
Alain
ip load-sharing per-packet
yes of course but It is highly recommend not to use per-packet load sharing.
Regards.
Alain
