09-18-2013 08:38 AM - edited 03-07-2019 03:33 PM
Good morning -
I am working on configuring the Archive command on 6509e VSS (VS40) and hit a snag that caused my slave 6509e to reload in rommon
Here is the config that caused this failure:
Archive
path bootdisk:/config-archive/$t_$h_config
maximum 5
write-memory
time-period 1440
After I did my copy run start the secondary slave detected a configuration mismatch and reloaded. I had to remove the code above and copy run start again in order to get matching configurations and VSS re-established.
I presume it has to do with the bootdisk command however I am trying to find the configuration example from Cisco.com or other VSS guide / Archive command guides without success.
Do I simply need to add 2 paths for the archive as such:
path slavebootdisk:/config-archive/$t_$h_config
maximum 5
write-memory
time-period 1440
And then copy run start?
I would try this but really would like it to be vetted as to avoid another slave failure.
Thank you for your input and assistance.
09-18-2013 09:51 AM
I have resolved this issue as follows:
The command path slavebootdisk:/config-archive/$t_$h_config did not work. However I was able to use my original configuration worked after I added the directory to the slavebootdisk.
IE:
mkdir bootdisk:/config-archive (already created as part of my first attempt)
mkdir slavebootdisk:/config-archive (missed in the first pass)
Once I added the slavebootdisk:/config-archive folder I was able to enable Archive on my 6509e VSS (VS40) devices.
Thank you for letting me brainstorm here and I hope this is of some help to somebody; sometime.
02-14-2018 02:11 PM
Hi John,
I realise this is an old post, but could you clarify something for me as I myself am struggling to find documentation on this.
To clarify, do you need both path statements (under archive) after creating both folders on bootdisk and slavebootdisk?
i.e.
conf t
archive
write-memory
Kind regards.
James
