Configure Port-Channel for Breakout 40G to 4*10G port
hbaytie01
I'm wondering if i have a breakout connection from 40G to 4*10G. What should be the configuration of the 4*10G ports, should it be port-channel to group the four 10G ports and do nothing on the other end of 40G?
Reza Sharifi
It could be either way. So, you can use the 10Gigs individually or bundle them using a Portchannel.
Reza Sharifi
