configure pppoe on 831 router with modem in bridge mode
Abertone1
Can some one please provide a config to setup PPPoE on the cisco 831 router to be used with a modem in bridge mode. I have tired other peoples configs found on the web but, not all the commands were available on the IOS version thats on the router. Also note that I bought this as a used router and I dont have a service contract so I am unable to download an updated IOS. The router ver is 12.3(7)T9 and the IOS is c831-k9o3sy6-mz.123-7.T9.bin. Running config below is last tried still could not connect or get ip address from isp. Wasent sure which ppp authentication to use so I used both pap and chap not sure if thats ok. Any help would be apreciated thanks...
831#sh run
Building configuration...
Current configuration : 1967 bytes
version 12.3
no service pad
service password-encryption
hostname 831
boot-start-marker
boot-end-marker
username bertone privilege 15 password 7 00071A150754
no aaa new-model
ip subnet-zero
ip domain name ackzz.com
ip name-server 4.2.2.2
ip audit po max-events 100
vpdn enable
vpdn-group 1
request-dialin
  protocol pppoe
no ftp-server write-enable
no crypto isakmp enable
interface Ethernet0
description $ETH-LAN$
ip address 192.168.2.3 255.255.255.192
ip nat inside
interface Ethernet1
no ip address
ip nat outside
duplex auto
pppoe enable
pppoe-client dial-pool-number 1
no cdp enable
interface Dialer1
ip address negotiated
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap pap callin callout
ppp chap hostname xxxxxxxxxxxxxxxxxxxxxxxx
ppp chap password 7 xxxxxxxxxxxxxxxxxxxx
ppp pap sent-username xxxxxxxxxxxxxxxxxx password 7 xxxxxxxxxxxxxxx
router rip
version 2
redistribute static
network 192.168.2.0
network 192.168.254.0
no auto-summary
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
ip http server
ip http authentication local
ip http secure-server
ip dns server
ip nat inside source list nat_address interface Ethernet1 overload
ip access-list standard nat_address
permit any
control-plane
banner motd ^C
     Authorised Access Only - Do Not Enter
^C
line con 0
exec-timeout 0 0
password 7 13061E010803
logging synchronous
login
no modem enable
transport preferred all
transport output all
line aux 0
line vty 0 4
exec-timeout 0 0
password 7 14141B180F0B
logging synchronous
login local
length 0
transport preferred none
transport input telnet ssh
transport output none
scheduler max-task-time 5000
cadet alain
you must put dialer 1 as nat outside interface and also change your nat statement like this:
no ip nat inside source list nat_address interface Ethernet1 overload
ip nat inside source list 10 interface dialer1
no ip access-list standard nat_address
access-list 10 permit 192.168.2.0 0.0.0.63
Let us know if this solves your problem.
Regards.
Alain
Hi Alan, didnt make any difference. Is there a simple config even with out nat just to connect to isp using pppoe on router conected to modem in bridge mode? I can do the nat part later, just want to connect for now, I remeber seeing some one do that on youtube a while ago
