Configure REP on 2960XR level 2 switch
Stu.Hicks3
My new 2960XR-24TS-I will not accept any REP configuration commands.
Is there a service that must be enabled before I enter the "rep admin vlan ###" config command?
reference :
Consolidated Platform Configuration Guide, Cisco IOS XE 15.2(4)E
(Catalyst 2960-XR Switch)
pp. 621-628
Got it working after a flash up to 15.2.  That's the minimum version for REP.
Have had no problems since then -- works as advertised!
6 Replies 6
Reza Sharifi
What is your license level?
Rep is not supported is you have LAN Base license.
Not -L.  It's -I.  You are correct that Lanbase does not support REP.
All I can figure is that there's a service I'm not turning on.....?
Di you get ahead with the issue or was it resolved in the later IOS version releases?
Great...
happy that its working fine..
cheers!
Stu.Hicks3
The "show version" command provides a little more information:  Version 15.0 (2a) EX5.
Can version 15.0 perform REP functions??  (most of the web literature refers to 15.1 and 15.2....)
