Configure: Switch to Phone to PC
bickyz9949
Hi I have Cisco 3560 switch.
Broadband
|                       ADSL (192.168.1.x)
- - - - - 3660 - - - - -
           LAN (10.1.1.x) - - - -PHONE-----PC1
3600 has two WAN connections. Generally all LAN clients access Internet via Broadband. All clients gets 10.1.1.x ip address. There is one PC who is connected to Phone and Phone is connected to the Switch.
Is there anyway I can configure switch so that Phone will get 10.1.1.x ip and PC will get ip from ADSL.
VLAN 100 (LAN 10.1.1.x)
VLAN 200 (ADSL 192.168.1.x)
Phone is connected to port 8 of the switch.
7 Replies 7
Ven Taylor
Level 4
Level 4
It depends on the phone and the router/switch.
If the phone supports vlan tagging and the router & switch support trunking, you can create a voice vlan and a data vlan.
I've never worked with a 3660 router, but the 3560 supports vlan trunking.
Try this configuration on your switch interface to the phone.
switchport mode access
switchport access vlan 10  <-- that's your data vlan
switchport voice vlan 20 <-- that's your voice vlan
The rest of your switch port config should be fine (duplex/speed/etc).
See if it works.
ven
Ven Taylor
cadet alain
the device providing DHCP service to your LAN devices ( PCs and phones ) must be either the 3660 router or a windows/linux server in your LAN not the ISP.
You can can and should put them into different vlans(subnets) though but by configuring 2 scopes.
Regards.
Alain.
@Ven Taylor
Typing error - my switch is 3560. Phone handset does support vlan tagging.
if psbl, could you roughly paste the configuration please.
@cadet alain
DHCP server is Windws 2003.
Phone & PC is connected to the single ethernet wall port. i.e. Phone is connected to the wall port and PC is connected to the Phone.
thanks to both of you.
The voice vlan config is the same for 3560 like Ven posted.
You'll have to create L3 interfaces for each VLAN : interface vlan x- ip address and then under the voice L3 interface configure ip helper-address x.x.x.x where x.x.x.x is unicat address of dhcp server in the data vlan.You'll also have to put a static route towards the voice vlan subnet in your dhcp server.
Regards.
Alain.
Bickyz:
Try this.
interface vlan10
description Lan 10.1.1.0/24
ip address 10.1.1.0 255.255.255.0
no shut
interface vlan20
description Voice 192.168.1.0/24
ip address 192.168.1.0 255.255.255.0
no shut
vlan 10
name Lan_subnet
vlan 20
name Voice_subnet
interfaceX/X
description Phone-PC1
switchport
speed auto
duplex auto
no shut
I didn't add any routing information because I don't know how you're routing.  Just make sure your subnets can see one another.
You also need to consider what Alain said.  Routers, by design, will supress broadcasts.
If your dhcp server is on a different subnet than your lan or voice, you'll need to add a helper-address to forward the dhcp requests to the server.  Syntax looks like this:
interface vlan10
ip helper-address x.x.x.x  <--- make this the ip of your dhcp server
no shut
interface vlan20
no shut
Lastly, if your phone uses special dhcp options (usually option 150 for tftp), you'll need to have them configured in your scopes.
Hope this helps.
Ven
Ven Taylor
thanks Ven, I will try it.
don't forget to add ip routing command to route between the subnets.
Alain
