Configuring 2811 for FoIP
julienf28
I have a VIC2-4FXO module that will be inserted into a 2811 router for FoIP Anybody have any ideas on how to configure this bad boy to make it work with our Fax server that is going to be in a virutual environement?
J
5 Replies 5
paolo bevilacqua
You are not giving enough detail about what you want to do.
here is a quick Visio drawing to explain what will be our setup.
Julien
Do you have CallManager in your network, if the answer is yes, you can check out this link.
http://www.cisco.com/en/US/docs/voice_ip_comm/fax_server/94/94ciscofaxigsupp.pdf
jerry
This is a great doc and we do have CUCM7.X but we are using Captaris RightFax server for the time being.
We are thinking of maybe going to UCM once our service contract is finished with Captaris.
Julien
I understand your are using Captaris RightFax server which is the same as Cisco Fax Server (Cisco OEM that from Captaris/Opentext). You can use that doc for call control. What that really does is when a fax call is received from the GW, it will use the CM to process the call, and the RightFax server is talking to CM via H.323 trunk. So this way, you have a single point for incoming and outgoing call processing via CM.
jerry
