Configuring A cisco 881 behind Telstra Gateway
Sean Coleman
Hi All,
Having some trouble and need some help if possible.
Scenario:
Client has just upgraded to FTTN with VDSL and Telstra DOT. Have been informed that we cannot remove the telstra gateway modem and it has to stay. Parent company of client has issued a Cisco 867 (although for the purposes of today i am using a 881 in the workshop to test before configuring the 867) to be setup and used for VPN connections.
Issue:
The telstra gateway device has an internal IP Address of 192.168.0.1 and a DMZ server address of 192.168.0.2.
We are unable to bridge the current modem due to telstra DOT hence DMZ.
Cisco router IP: 192.168.199.1 (SVI/VLAN1)
WAN port IP: 192.168.0.2
Static Route 0.0.0.0 0.0.0.0 192.168.0.1
IP routing Enabled
I am unable to ping or get internet connection from a pc attached to port 1.
from the PC i can ping .199.1, 0.2 but not .0.1.
I am able to ping 8.8.8.8 & 8.8.4.4 from the router and it succeeds and i can ping the computer on 192.168.199.11 (DG 192.168.199.1)
Any Assistance would be appreciated, Please see config attached below.
Router(config)#do show run
Building configuration...
Current configuration : 903 bytes
! Last configuration change at 07:20:55 UTC Tue Jun 20 2017
version 15.0
no service pad
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 10
ip source-route
ip cef
no ipv6 cef
license udi pid CISCO881-K9 sn FHK13437387
vtp version 2
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
ip address 192.168.0.2 255.255.255.0
duplex auto
speed auto
interface Vlan1
ip address 192.168.199.1 255.255.255.0
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 192.168.0.1
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
login
scheduler max-task-time 5000
end
Router(config)#exit
Router#wr
[OK]
Router#
*Jun 20 07:42:55.203: %SYS-5-CONFIG_I: Configured from console by console
2 Accepted Solutions
Mark Malone
your config looks ok as your just punting your traffic up to the Telstra gateway which is in control of the NAT I presume and the routing too
couple of things to check
make sure the Telstra has a route back to your local network a static setup for return traffic this is important
make sure Telstra is setup for NAT correctly as that's the edge facing device and all subnets on the local router are natted when trying to reach the internet
you may not be able to ping a DMZ device as per security policy depending on the device it may be blocking icmp so you may want to try another test
Mark Malone
Hi Mark,
Thanks for your reply. The Telstra modem works perfectly fine for all devices plugged into it directly, NATing appears to be working as any device connected can get out and back in.
I am able to ping the Modem from the cisco router no hassles, i can ping its interface of 192.168.0.1 and get full response.
ill have a look at putting in a route back to the device.
Kind Regards,
Sean.
Hi Mark,
Looks like its resolved now,
i put in a static route on the modem as follows:
DEST 192.168.199.1
SN: 255.255.255.0
GW: 192.168.0.2
and it is now working.
thank you very much.
Good stuff
