Configuring a VLAN for WiFi guests
Merrily Mundane
I have a Cisco Catalyst 2970 switch with a Firewalla firewall on port 13 and a  Linksys MX4000 V2 running OpenWRT on port 3.
I would like my Cisco to provide trunks to these to ports for VLANs 1 (default) and 99 (guest).
If I connect my Linksys directly to my Firewalla, my guest traffic is correctly tagged VLAN99 and all others with VLAN1. But when I go through my Cisco, all traffic remains on the default network.
What do I need to change in my switch configuration to get the desired behavior?
Switch#show int Gi0/3 trunk
Port Mode Encapsulation Status Native vlan
Gi0/3 on 802.1q trunking 1
Port Vlans allowed on trunk
Gi0/3 1-4094
Port Vlans allowed and active in management domain
Gi0/3 1,99
Port Vlans in spanning tree forwarding state and not pruned
Gi0/3 1,99
Switch#show int trunk
Gi0/5 on 802.1q trunking 1
Gi0/13 on 802.1q trunking 1
Gi0/3 1-4094
Gi0/5 1-4094
Gi0/13 1-4094
Gi0/3 1,99
Gi0/5 1,99
Gi0/13 1,99
Gi0/3 1,99
Gi0/5 1,99
Gi0/13 1,99
Switch#show int vlan99
Vlan99 is up, line protocol is up
Hardware is EtherSVI, address is 0015.fa04.b441 (bia 0015.fa04.b441)
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
Last input 00:00:03, output never, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
56128 packets input, 18114955 bytes, 0 no buffer
Received 0 broadcasts (0 IP multicast)
0 packets output, 0 bytes, 0 underruns
0 output errors, 0 interface resets
Switch#show int vlan1
Vlan1 is up, line protocol is up
Hardware is EtherSVI, address is 0015.fa04.b440 (bia 0015.fa04.b440)
Internet address is 192.168.173.254/24
Last input 00:00:00, output 00:00:00, output hang never
432366 packets input, 52744175 bytes, 0 no buffer
35452 packets output, 2358921 bytes, 0 underruns
Why ypu not make guest in vlan 99 for both fw and cisco ?
I dont get what you want exactly
MHM
I have a guest wifi network. My Linksys is configured to put guests on VLAN 99 and all other WiFi clients on the default VLAN 1.
My firewall is configured to provide clients on VLAN99 a different set of rules and IP addresses from clients on VLAN 1.
If I connect my Linksys directly to a port on my firewall, this works as expected. If I put the Cisco switch between the firewall and WiFi, then my guest network clients are given the same IP and rules as my default network clients.
