08-14-2017 01:12 PM - edited 03-08-2019 11:44 AM
This is my first time configuring a virtualized ASA (9.8.1) in GNS3 for use in CCNAS class. The configuration is as follows:
ASAv g0/0 - 10.10.10.2 > HUB > Loopback 10.10.10.1 (Local PC)
I'm trying to ping the Loopback address from the ASAv and vice versa. I know the loopback is in working order because I was able to ping it from a virtualized C7200 router.
I'd like to know the configurations in order to get the ASA ping and be ping-able
Hub is used instead of switch because GNS3 ethernet switch is buggy
Solved! Go to Solution.
08-15-2017 12:52 AM
Thanks for the speedily reply. The Cloud in the topology represents the loopback address.
10.10.10.1 is the Loopback interface's configuration on the Windows side of the topology. I've used a router in place of the ASA prior to testing it with an ASA and it was reachable from both directions.
08-14-2017 03:50 PM
Hello
I am assuming from you topology that the lan address is 10.10.10.1 and the loopback is another address?
Please try the below example:
interface GigabitEthernet0
nameif Inside
security-level 100
ip address 10.10.10.2 255.255.255.0
object network LAN1
subnet 10.10.10.0.255.255.255.0
object network LAN2
subnet (loopback address) 255.255.255.255
object-group network ICMP-ECHO
network-object object LAN1
network-object object LAN2
access-list 100 extended permit icmp any object-group ICMP-ECHO echo-reply
route Inside (loopback address) 255.255.255.255 10.10.10.1
res
paul
08-15-2017 12:52 AM
08-15-2017 01:16 AM
[UPDATE]
After using the configurations mentioned above with the necessary adjustments pinging to and from the ASA was unsuccessful
Once again I'd like to clarify that my Windows-side firewall is allowing ICMPs both to and from itself (host) this is a matter of the ASA requiring necessary configurations to allow ICMP both out and in from within the local network.
Both networks Windows-side and in the virtualized environment are within the same subnet.
Thanks in advance
