QoS: Output drops and wrong throughput on 3850
dvag-nsafe
Hi!
I have two issues here with QoS on a 3850.
1. I have a policy configured on the uplink to another switch outgoing. i have a client connected to that switch sending DSCP 46 marked packets.
When looking a the stats, i see excessive drops on the policy-map. Are those drops from default traffic? or are they from the DSCP 46 stream? iperf says i have almost no loss. I'm sendin g UDP traffic between two laptops.
Policy-Map:
 Policy Map UPLINK_OUTGOING
    Class VOICE
      priority level 1 10 (%)
     police cir percent 10
       conform-action transmit
       exceed-action drop
    Class VIDEO
      priority level 2 20 (%)
     police cir percent 20
       exceed-action drop
    Class class-default
      bandwidth remaining 100 (%)
Interface config:
interface TenGigabitEthernet1/1/1
 description sw-lab-c6800-1 t1/1
 switchport trunk native vlan 2
 switchport trunk allowed vlan 10
 switchport mode trunk
 channel-group 10 mode active
 service-policy output USER_OUTGOING
end
interface TenGigabitEthernet1/1/2
 description sw-lab-c6800-1 t1/2
end
interface Port-channel10
end
Statistics after sendign a 10MBit/s Stream:
  Service-policy output: USER_OUTGOING
    queue stats for all priority classes:
      Queueing
      priority level 1
      (total drops) 7748
      (bytes output) 12753854
      Queueing
      priority level 2
      (total drops) 0
      (bytes output) 0
    Class-map: VOICE (match-any)
      9087 packets
      Match: ip dscp ef (46)
        0 packets, 0 bytes
        5 minute rate 0 bps
      Priority: 1% (100000 kbps), burst bytes 2500000,
      Priority Level: 1
      police:
          cir 1 %
          cir 100000000 bps, bc 3125000 bytes
        conformed 12781448 bytes; actions:
          transmit
        exceeded 0 bytes; actions:
          drop
        conformed 40000 bps, exceeded 0000 bps
    Class-map: VIDEO (match-any)
      0 packets
      Match: ip dscp af41 (34)
        0 packets, 0 bytes
        5 minute rate 0 bps
      Priority: 5% (500000 kbps), burst bytes 12500000,
      Priority Level: 2
      police:
          cir 5 %
          cir 500000000 bps, bc 15625000 bytes
        conformed 0 bytes; actions:
          transmit
          drop
        conformed 0000 bps, exceeded 0000 bps
    Class-map: class-default (match-any)
      4465 packets
      Match: any
      Queueing
      (total drops) 0
      (bytes output) 357826
      bandwidth remaining 100%
2. The Links are both 10GBit/s, iconfigured the VOICE class to be 1% of the bandwidth, so i should have a max throughput of 100MBit/s in that class, right?
But i can only get a maximum of 10MBits when this policy is applied! When sending a 100MBit-Stream, i have 85% packet loss.
Please help,
Christian
0 Replies 0
