Configuring Breakout Cable in Nexus
cdowling_bm
Hi there,
Has anyone installed a breakout cable (QSFP-4SFP10G-CU) into a Nexus switch and configured only a couple of the SFP connections as a port channel i.e. creating a 20Gb port channel?  If so, can the remaining two 10Gb ports be used independently?
I also need a config guide and/or examples of how to do the configuration above.
Thanks.
Charles.
Reza Sharifi
Yes, you can use the remaining 10Gig interfaces for whatever you like.  They are just like any other 10Gig interfaces.
 Breakout command config guide:
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus6000/sw/interfaces/6x/b_6k_Interfaces_Config_Guide_Release_6x/b_6k_Interfaces_Config_Guide_Release_602N12_chapter_0101.html
