Configuring C2960x with Dell switch
yeow28
I need to add one C2960X switch to my DellS3148 switch.
what are the things to take note for the trunk port between the 2 switches.
will be using normal UTP cables to connect both.
my management vlan is VLAN2 and I need VLAN1, VLAN2 and VLAN16 on the connecting port while access port will be VLAN16.
 Both support 802.1Q as per the Datasheet from both vendors. Theorically, they will work.
