configuring cisco2901
hello all,
i am about to configure cico 2901 with this set-up (attached file)..
how am i going to start with this? what do i need to know? if example i have the leased ip 125.212.33.x/30 what will i as management for the router? will i used NAT for this?
thanks
17 Replies 17
It seems you dont have physical connection -What are cable type are you connecting to this modem with?
Going back to the original question - what type of service are you receiving from your ISP?
res
Paul
Please don't forget to rate any posts that have been helpful.
Thanks.
Kind Regards
Paul
im not yet connecting the router to the modem.. i want to up it 1st by configuring its command..
do i need to connect the modem to the router before i can do command:
Router1(config)#int gigabitEthernet 0/1
Router1(config-if)#ip add 192.168.20.1 255.255.255.0
Router1(config-if)#no shut
type of service is leased line
