Configuring DHCP pool on ASA in packet tracer
cisconotdisco
I'm very, very new to working with packet tracer/configuring firewalls and I'm having problems getting my DHCP pool to work properly. I moved it from my router to my ASA. I've posted the configuration of the ASA below. Any help is very much appreciated, I've spent a lot of time on this!
branchASA#sho run
: Saved
ASA Version 8.4(2)
hostname branchASA
enable password hxG7F/4eupjTnxQQ encrypted
names
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
nameif inside
security-level 100
ip address 35.32.17.254 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address 32.35.17.1 255.255.255.0
access-list inside extended permit icmp any any
access-list outside extended permit icmp any any
access-group inside in interface outside
access-group outside in interface inside
telnet timeout 5
ssh timeout 5
dhcpd address 35.32.17.50-35.32.17.99 inside
dhcpd dns 17.35.32.153 interface inside
dhcpd enable inside
branchASA#
Julio E. Moisa
Your config looks fine, I assume you are connecting the host to the port 1 to 7 and setting up the host to obtain IP automatically, Also you can fix this configuration:
it should be
access-group inside in interface inside
access-group outside in interface outside
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Julio E. Moisa
it should be
Thank you very much for your help!
