configuring dhcp pool with different class subnet
mhasabal
i am trying to configure dhcp pool with classless network address:
network 172.20.1.0 255.255.0.0
default-router 172.20.1.254
but when i do sh run,the router config shows the following:
network network 172.20.0.0 255.255.0.0
is there a command i can use to stop the router from using the default classfull address.
thank you for your help.
Lucien Avramov
Level 10
Level 10
Well you need to make up your mind:
either you use network 172.20.1.0 255.255.255.0 and that will do what you want or you keep network 172.20.0.0 255.255.0.0
I think you have a typo in your network statement you needed 255.255.255.0
lavramov,
thank you for the reply. the reason i need to configure the inside interface and the dhcp pool that way is because i have NEC phone system that i am not familiar with and don't want to change IP address cause it will create a chain of problems.
