configuring dhcp relay
carl_townshend
Hi all, Can anyone tell me how I would enable this on my router or switch, so my dhcp server can be centralised, and How could I make it so the subnet where the dhcp server sits does not recieve offers for all my scopes setup on the server ?
jmonk
You use the helper-address command. For the VLAN interface use as follows:
ip helper-address x.x.x.x
Where x.x.x.x = dhcp server
Joe
acomiskey
Level 10
Level 10
To answer the 2nd part of your question, the server will know the source address (vlan) of the dhcp request and hand out the appropriate address in the corresponding scope. If you are on vlan 10 you will get a vlan 10 address and so on.
dahuja
Go through this doc, this will answer all your questions
http://www.cisco.com/warp/customer/473/100.html
If you need further help , feel free to contact me.
