Configuring HSRP w/ InterVlan Routing
james.sabia
I have configured HSRP with InterVlan routing. All communication is flowing properly between the vlan's on Router A but when I test failover to Router B I cant ping ANYWHERE. I cannot ping any of the VLANS.
Also, From the primary router I cannot ping any of the interfaces on the secondary router.
I have 2 Cisco 1921 Routers configured for HSRP. Both the G0/1 ports plug into a Cisco 2960S 48 port POE switch (STACKED) (port 1 and port 2 which are trunked and allowing all vlans to pass through. And both of the G0/0 ports are plugged into a Cisco ASA5510.
I have attached a diagram of the setup and the interface configs of the routers.
As for the ports 1 and 2 on the switch, the only commands on them are:
switchport mode trunk
switchport trunk native vlan 99
Any help is greatly apprectiated.. If you would like the actual router/switch configs please let me know.
when you test the failover what you made?
shut some port or power off one router?
