Configuring HSRP w/secondary ip
brooklynheight
We currently have a 3845 configured
with a secondary interface on the ge
nterface GigabitEthernet0/1
description connection to lan
ip address 192.168.2.222 255.255.255.0 secondary
ip address 192.168.2.236 255.255.255.0
My question is..how would i configure hsrp to include these two ip's and
2 different ip's on the new router..
for a total of 4 ip's in one group
ankbhasi
Hi Friend,
Is there any specific reason you have configured same subnet ip address as primary and secondary and then you want HSRP to run for both the ip address?
You can configure hsrp for primary as well as secondary ip address using command
standby ip
standby ip secondary
http://www.cisco.com/en/US/products/sw/iosswrel/ps5207/products_feature_guide09186a00801d2d21.html
Ankur
*Pls rate all helpfull post
Hello-I am new here and just found out the config to be that way..thx for your help!
Something like this will work:
C2621#sh run int f1/0
Building configuration...
Current configuration : 1315 bytes
interface FastEthernet1/0
description DMZ Network
ip address 192.168.1.194 255.255.255.128 secondary
ip address 192.168.0.130 255.255.255.128 secondary
ip address 192.168.155.242 255.255.255.248 secondary
ip address 10.100.197.2 255.255.255.240 secondary
ip address 172.25.2.242 255.255.255.240 secondary
ip address 192.168.0.2 255.255.255.128
ip accounting output-packets
ip accounting mac-address input
ip accounting mac-address output
ip nat inside
ip flow ingress
ip route-cache flow
speed 100
full-duplex
standby 1 ip 192.168.0.1
standby 1 priority 105
standby 1 preempt
standby 1 authentication hsrp_1
standby 1 name HSRP_DMZ_1
standby 2 ip 192.168.1.193
standby 2 priority 105
standby 2 preempt
standby 2 authentication hsrp_2
standby 2 name HSRP_DMZ_2
standby 3 ip 192.168.0.129
standby 3 priority 105
standby 3 preempt
standby 3 authentication hsrp_3
standby 3 name HSRP_DMZ_3
standby 4 ip 192.168.155.241
standby 4 priority 105
standby 4 preempt
standby 4 authentication hsrp_4
standby 4 name HSRP_DMZ4
standby 5 ip 10.100.197.1
standby 5 priority 105
standby 5 preempt
standby 5 authentication hsrp_5
standby 5 name HSRP_DMZ_5
standby 6 ip 172.25.2.241
standby 6 priority 105
standby 6 preempt
standby 6 authentication hsrp_6
standby 6 name HSRP_DMZ_6
end
C2621#
CCIE Security
