Configuring IP of untagged VLAN
gnanavel.ns
I will be connecting a Router LAN port to a trunk port in a switch. The trunk will carry VLAN 320 and VLAN 1, which will be untagged. The management network is carried in VLAN 1. If I have to configure the IP of VLAN 1 in Router, should I configure it in the main interface (with VLAN 320 IP in the sub interface .320 with dot1q encap)?
Gnanavel.
Jon Marshall
Should work either so yes you can do it as you suggest.
Jon
