Configuring lacp port channeling
Fabri_Fabri
I am trying to configure LACP through 2 Cisco switches 2960s.
This is my configuration:
SW1 & SW2
interface GigabitEthernet1/0/47
 description PORT_CHANNEL
 switchport access vlan 9
 speed 1000
 duplex full
 channel-protocol lacp
 channel-group 1 mode active
interface GigabitEthernet1/0/48
 speed 1000
 duplex full
Will active on both sides be ok ?
Right now port-channel is configured this way:
interface Port-channel1
 description PC1
Does port-channel interface need to be configured regarding switchport and/or speed and/or duplex or is it related only to physical ports ?
Any help appreciated. Best regards.
13 Replies 13
Reza Sharifi
Yes, both sides can be configured as active
You don't need to configure the Portchannel with speed and duplex, but you need to configured it as access or trunk.
Hi Reza, thanks for reply.
Do you think that this configuration will work ?
 description PC1
or this one is better ?
 description PC1
 switchport mode access
I also plan to set up both physical ports configuration and port-channel configuration the same way on both switches. Is it correct ?
Do you see any other errors in this config ?
Best regards.
use this config
 description PC1
 speed 1000
 duplex full
it should work fine on all switches.
Can I ask you why you removed this line:
Is it implicitly activated using "active" ?
Thanks.
Correct.  That is on optional command and the switch already knows what protocol you are using (in this case LACP) when you issue
Thank you Reza, your help is greatly appreciated.
turns out that DUPLEX FULL causes link to not work. I mean Layer1: sh interface reported link gi1/0/48 id down: line protocol is down.
Turning off duplex to auto on both sides immediately connected the links.
It is pretty strange isn't it ?
Last question: portchannel interface has to be access or trunk ? I need only 1 vlan.
Thanks.
satishpadhy
i also similar problem , i m trying to connect 3945 router with HP Switch. router gives when mode active used
 no ip address
 hold-queue 150 in
interface Port-channel1.255
 encapsulation dot1Q 255 native
 ip address 191.168.1.1 255.255.255.0
interface GigabitEthernet0/0
description Uplink to <Switch name> Gig1/0/x
no ip address
duplex full
speed 1000
interface GigabitEthernet0/1
description Uplink to <Switch name> Gig2/0/x
no ip address
duplex full
speed 1000
What is the problem you face with it?
mode active doesn't take the command hence port channels are not working.
I m not from the routing team, but i have a feeling if the command is not accepted , then it may be that you don't have the required license for that.  But i am not 100% sure.
As a work around you may configure it as mode "ON" .
Madhu.
actually no option either for mode active or ON. Does 3945 supports LACP ?
(config-if)#channel-group 1 on
% Invalid input detected at '^' marker.
