configuring nexus on ccw
rahil.mohammed
Hi All,
I am configuring NEXUS hardware on CCW. But I am wondering which is better, is it possible to choose only F series modules rather than M series and could achieve L3 and L2, MPLS with nexus specific features like OTV,LISP,Fabricpath. Or M series module is also required? Kindly elaborate.....
eduardopozo56
You can find all the info for supported features for the F and M modules on the Nexus infosite:
http://www.cisco.com/c/en/us/products/switches/nexus-7000-series-switches/models-comparison.html#~tab-b
You also need to check your Power/Routing Tables/Latency/Others requirement, M modules are mostly for IP Based services and F modules for L2/Datacenter services:
http://www.cisco.com/c/en/us/td/docs/solutions/Enterprise/Data_Center/VMDC/2-6/vmdcm1f1wp.html
eduardopozo56
