Configuring OSPF on a layer 3 switch 3560G
asencalar
Configuring OSPF on a catalyst 3560G Switch to connect to our building next door by way of fiber.  The other two switches in the other building are running OSPF, I am trying to connect to the other building and access a server which is on a switch running OSPF.  I am trying to configure the switch here to run OSPF and be able to see the neighbor, but currently can't although I've identified the networks.  Maybe I'm missing something, I've followed the instructions but  something is not right.  Can anyone help in possibly identifying or certain things that I need to look no matter how basic it may be.
19 Replies 19
Can you please post some configuration like
Sh ip ospf neighbors
This is to identify the neighbor state.....
sh run par router ospf(process id) or sh run | sec router ospf  ( this is for all the switches)
Also provide the topology
Topology as per the above comments what I have assumed is
SW1----> SW2
SW3(new 3560 SW) is this correct..
Thanveer
"Everybody is genius. But if you judge a fish by its ability to climb a tree, it will live its whole life believing that it is a stupid."
Hello
How are you connecting to the neighbor ( what physical interface - I guess gigabit/fastethernet-  which in ospf terms is a broadcast link)
From the switch-
sh ip ospf interface xxx
sh ip ospf neigbours
res
Paul
Please don't forget to rate any posts that have been helpful.
Thanks.
Kind Regards
Paul
This was very helpful.  I had configured wrong and found this post, got it all fixed up now.
use ipv6
asencalar
SwitchR4S1#show run | sec router ospf
router ospf 110
router-id 10.12.0.12
area 0 authentication message-digest
passive-interface default
no passive-interface Vlan804
no passive-interface Vlan1000
network 10.12.0.12 0.0.0.0 area 0
network 10.12.255.1 0.0.0.0 area 0
network 148.32.14.253 0.0.0.0 area 0
SwitchR4S1#
SwitchR4S1#sh ip ospf neighbor
SwitchR4S1#
SwitchR4S1#sh ip ospf interface
Vlan804 is up, line protocol is up
  Internet Address 148.32.14.253/24, Area 0, Attached via Network Statement
  Process ID 110, Router ID 10.12.0.12, Network Type BROADCAST, Cost: 1
  Topology-MTID    Cost    Disabled    Shutdown      Topology Name
        0           1         no          no            Base
  Transmit Delay is 1 sec, State DR, Priority 1
  Designated Router (ID) 10.12.0.12, Interface address 148.32.14.253
  No backup designated router on this network
  Timer intervals configured, Hello 10, Dead 40, Wait 40, Retransmit 5
    oob-resync timeout 40
    Hello due in 00:00:03
  Supports Link-local Signaling (LLS)
  Cisco NSF helper support enabled
  IETF NSF helper support enabled
  Index 2/2, flood queue length 0
  Next 0x0(0)/0x0(0)
  Last flood scan length is 0, maximum is 0
  Last flood scan time is 0 msec, maximum is 0 msec
  Neighbor Count is 0, Adjacent neighbor count is 0
  Suppress hello for 0 neighbor(s)
  Message digest authentication enabled
      No key configured, using default key id 0
Vlan1000 is up, line protocol is up
  Internet Address 10.12.0.12/24, Area 0, Attached via Network Statement
        0           1         no          no            Base
  Transmit Delay is 1 sec, State DR, Priority 255
  Designated Router (ID) 10.12.0.12, Interface address 10.12.0.12
  Index 1/1, flood queue length 0
  Next 0x0(0)/0x0(0)
SwitchR4S1#
router ospf 110
SwitchR4S1#
SwitchR4S1#
        0           1         no          no            Base
  Next 0x0(0)/0x0(0)
        0           1         no          no            Base
  Next 0x0(0)/0x0(0)
SwitchR4S1#
OK so this is what I have, it is a closed network so we don't touch anything like the internet.  The fiber is ran between the two buildings with two switches on one end and the switch I'm trying to configure on this end (10.12.0.12).  The other end is 10.12.0.1
Sorry for the delay in the response.
As per the above output the switch you are trying to configure also has neighbors other than the one which you are configuring..
are you able to reach the other end switch which you are trying to configure. Please provide the ping status...
I am a bit worried with the below output, I have highlighted the output which I am worried about..
        0           1         no          no            Base
can you post the config for the below
sh run int (interface connecting with the other switch)
Is the port you are trying to connect is L3, or L2?
If L2 then the interface must be accessing the vlan 1000
example
interface GigabitEthernet0/1
switchport access vlan 1000
switchport mode access
you should get the output for sh ip ospf neighbor
example
Switch#sh ip ospf neighbor
Neighbor ID     Pri   State           Dead Time   Address         Interface
1.1.1.2           1   FULL/BDR        00:00:32    1.1.1.2         Vlan1000
Please rate the helpful posts
Thanveer
Both switches are L3. The other side is connected internally, I'm trying to establish connection into the ospf neighborhood from this building across the street. I am actually at the switch working with it to get it to work
What should the router-id be, when I put 10.12.255.1 which is the configuration on the switch which works and is the other building, I get a duplicate router-id message?
What networks should I put in the configuration of the ospf, the ip of the switches that I want to add and/or what else?
Ping works
Unable to trace route
Hello Ates,
router-id can be any loopback address or the add which you want, there will be no issue.
prerequisties
you must be able to ping the neighbor switch ip address.
for (IGP/ospf) to get configured the other switch must be a directly connected neighbor only then you will be able form a adjacency relation ship.
Switches for which you need to form a neighbor relationship must be in a single broadcast domain.
If your switch  port is L2 then it must be accessing the vlan 1000 as per your requirement.
The other side switch ospf process also should have area 0 configured on the interfeace with which you need to form adjacency  (If you need area 0 to be configured in your switch)
configuration part:
Router ospf 110
network 10.12.0.12 0.0.0.0 area 0 (this is the vlan interface ip address of the local switch, if your intentions is to make the neighbor relationship based on the vlans)
network 20.1.1.0 0.0.0.255 area 0 (I assumed 20.1.1.0/24 as your local LAN, It can be any network which is down to your switch and you wanted to advertise it into ospf process).
OR
router ospf 110
int vlan 1000
ip ospf 110 area 0
Thanveer
I will let you know on Monday as to how it goes. Thanks for the help!
Any luck?
Thanveer
