Configuring OSPF on a layer 3 switch 3560G
asencalar
Configuring OSPF on a catalyst 3560G Switch to connect to our building next door by way of fiber.  The other two switches in the other building are running OSPF, I am trying to connect to the other building and access a server which is on a switch running OSPF.  I am trying to configure the switch here to run OSPF and be able to see the neighbor, but currently can't although I've identified the networks.  Maybe I'm missing something, I've followed the instructions but  something is not right.  Can anyone help in possibly identifying or certain things that I need to look no matter how basic it may be.
19 Replies 19
I will let you know once I try your suggestions, thanks for checking.
I got it working thank you for your assistance, it had to do with the authentication, I didn't have the "ip ospf message-digest- key" in VLAN 1000, now I can see the neighbors.
Thats good to hear Ates.
Thanveer
"Everybody is genius. But if you judge a fish by its ability to climb a tree, it will live its whole life believing that it is a stupid."
Thank you for the tip. I had an issue with OSPF between a Router and a Switch and I had to add that on both sides to avoid Network Type BROADCAST:
R1#
interface GigabitEthernet0/0
ip address 10.10.100.1 255.255.255.0
ip ospf network point-to-point
S1#
interface Vlan100
ip address 10.10.100.2 255.255.255.252
Can you please share both devices configuration. if [possible please share logs let me try
