Configuring SPAN port for Websense
pcybulski
I saw similar posts but I am still lost and my configuration is a bit different.  I have configured a SPAN port on my Cisco 4510 switch, however I am not seeing the desired traffic in my Websense server.  I am verifying using Wireshark as suggested by Websense support, but I am seeing no results.
Here is the show monitor for the session I created:
Session 4
Type                   : Local Session
Source VLANs           :
    Both               : 1-252
Destination Ports      : Fa7/2
    Encapsulation      : Native
          Ingress      : Enabled, default VLAN = 1
         Learning : Disabled
Filter Pkt Type        :
    RX Only       : Good
We have a lot of VLANs and I am trying to monitor almost all of them to see what type of bandwidth is being used.
Suggestion from Websense support:
You can run Wireshark against the NIC you're port spanning to and use the filter:
http contains purple.com
Each time you feel you may have configured your port span correctly, go to purple.com from a workstation that should be passing through the configured port span. You should see a GET request packet appear in WIreshark if your port span is correctly configured.
Jose Solano
Level 4
Level 4
Hi Paul,
In this case, I see that you are sending traffic from vlans 1-252 to a fast ethernet port. Do you see any drops on that interface? It just because I would say that the amount of traffic is too much for a Fastethernet port which may cause congestion and output drops. Therefore you might not see all traffic as desire.
Hope this helps.
John Blakley
Paul,
Can you post "sh run | i monitor"?
HTH,
John
HTH, John *** Please rate all useful posts ***
Here is how I have my port configured at the moment:
interface FastEthernet7/2
switchport mode access
end
monitor session 4 source vlan 1 - 252
monitor session 4 filter packet-type good rx
monitor session 4 destination interface Fa7/2 ingress vlan 1
Session 4
Source VLANs           :
    Both               : 1-252
         Learning : Disabled
Filter Pkt Type        :
    RX Only       : Good
