03-03-2012 09:20 AM - edited 03-07-2019 05:19 AM
I have two servers, connected on two(Different) 6513 directly connected switches.
Both these servers are in the same Vlan.
I have to monitor communication these two servers.
I have a system connected on one of the 6513 switch, where network tool wireshark is installed.
Need help to configure span port.
switch 6513-1# show run int Gi10/43 --------------------Server 1 is connected
switch 6513-2# show run int Gi9/45 ------------------------Server 2 is connected
switch 6513-2# show run int Gi9/46 ------------------------System on which network tool wireshark is installed.
Solved! Go to Solution.
03-06-2012 01:09 PM
You wouldn't need to modify the port that the servers are on. You create a vlan for span traffic only. Something like the following:
Switch A:
vlan 999
remote-span
monitor session 1 sourc int g 4/5
monitor session 1 destin remote vlan 999
Switch B:
vlan 999
remote-span
monitor session 1 source remote vlan 999
monitor session 1 destin int g 4/24
You would connect your Wireshark box/analyzer to port g4/24 on Switch B. Traffic that's sent on Switch A on port 4/5 (assuming where your server is) will get copied to the vlan. Make sure that your vlan 999 is on the trunk between the two switches.
John
Please rate all helpful posts.
03-03-2012 09:30 AM
Some correction, wireshark is installed on server 2
03-03-2012 02:32 PM
you can monitor only server 1 because wireshark is installed on server 2
A SPAN destination port cannot be a source port, and a source port cannot be a destination port.
monitor session 1 source interface Gi10/43
monitor session 1 destination interface Gi9/45
03-03-2012 07:30 PM
Got your point. I will get wireshark installed on another system, say, that system is connected on 6513-2 switch port number Gig9/46.
Again all these are in the same Vlan, that is Vlan 4.
03-03-2012 07:34 PM
Again, if we have monitor server 1 which is connected on switch 6513-1 and wireshark is installed on system which is connected on switch 6513-2.
I need to know the configuration for both these scenario.
03-04-2012 08:56 PM
If wireshark installed on another system, say, that system is connected on 6513-2 switch port number Gig9/46
monitor session 1 source interface Gi10/45
monitor session 1 destination interface Gi9/46
03-05-2012 04:51 AM
In my case server 1 is connected on switch 6513-1 and server 2 is connected on switch 6513-2.
Again system on which wireshark is installed is also connected on switch 6513-2.
Queston.
What commands need to be enabled on switch 6513-1
and what command need to enabled on switch 6513-2
All these devices are in the same Vlan.
03-05-2012 05:31 AM
Because these 2 hosts are on 2 separate switches, you're probably going to need to set up an RSPAN session. You'll create a special remote span vlan and add that to your trunk between the 2 switches. Then the switch that you set up as a source, its destination is the vlan that you created and on the destination switch, its source is the RSPAN vlan.
Check here:
03-06-2012 12:44 PM
As you mention adding special remote span vlan to the trunk.
Do I need to add this vlan to the switch interfaces to which these servers are connected.
These servers are already in Vlan 4.
03-06-2012 01:09 PM
Switch A:
vlan 999
remote-span
Switch B:
vlan 999
remote-span
John
