Configuring Supervisor Engine Redundancy
Arun Kumar Thakur
Frequent Visitor
Frequent Visitor
How to configure Supervisor Engine Redundancy between two different cisco 4507R and 4506E.
2 Accepted Solutions
What do you mean exactly about "Supervisor Engine Redundancy between two different cisco 4507R and 4506E"
Are you looking for some kind of Redundancy between these two switches.
Then nothing to do with supervisor engines.
You can configure two supervisor engines in one switch like 4507R for one active and another for standby.
And for your information Supervisor engine redundancy does not provide supervisor engine load balancing or any other feature requiring two active supervisor engines. Only one supervisor engine is active. Network
services are disrupted until the standby supervisor engine takes over and the switch recovers.
Please see the below link for how to configure the supervisor engine and to make better understand of it.
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.1/12ew/configuration/guide/RPR.html#wp1097801
Please rate all the helpfull posts.
Naidu.
Again high availability can be differentiate...
Like in a single 4507R switch you can have just supervisor engine redundancy (RPR) this is just for...
Supervisor engine redundancy does not provide supervisor engine load balancing or any other feature requiring two active supervisor engines. Only one supervisor engine is active. Network services are disrupted until the standby supervisor engine takes over and the switch recovers.
So if one SUP is gone or down then the other (standby) SUP will take over the job.
And you can do Online insertion and removal (OIR) of the standby supervisor engine and Software upgrade (IOS) without having down time.
Coming to high availability between 4500 switches.
I think you have different floors and multiple 4500 switches.
What I would suggest is interms of high availability, keep two switches in HSRP mode to have a complete switch redundancy.
It is like this, say you have one switch as a default gateway for all your LAN, if this switch fails then the specific LAN can not communicate with others.
If you keep two switches in HSRP, then one switch will be active and another will be standby. So if one switch fails then the other switch will take over the job so that the LAN will never get outage.
Let me know if you need any help regarding HSRP, will provide you the solution.
Naidu.
5 Replies 5
Joseph W. Doherty
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
Are you asking about VSS on the 4500s?
Naidu.
I have a couple of cisco 4500 series switches.
Which is the best way to get high availabilty?
Naidu.
Amarjeet,
What Latchum is trying to say is that you need to give basic information about your topology, what you want to achieve and the basic infrastructure that you have. It is hard to give a solution when you do not know the environment. There are a lot of questions that need to be answered here:
Seeing that your are using the 4506E, that has a capacity for only 1 supervisor so like Latchum said, you best bet would be to have the 4507R which has a capacity for 2 sups. See the matrix here:
http://www.cisco.com/en/US/customer/prod/collateral/switches/ps5718/ps4324/product_data_sheet0900aecd801792b1.html
I would presume the best way if you have 4706E, would be to have these two as your core and run a redundancy protocol of your choice, of which HSRP is the most common.
Have some vlans as primary on one and standby on the other. Most places they would have odd numbers on one and even numbers on the other....
example:
Switch 1
interface Vlanxx
description
ip address 10.x.x.2 255.255.255.0
  standby xx ip 10.x.x.1
standby xx priority 105
standby xx preempt
end
Switch 2
interface Vlanxx
description
ip address 10.x.x.3 255.255.255.0
  standby xx preempt
end
Hope this helps
