configuring Timezone
bkoum
Level 3
Level 3
Hello, im trying to catch the change of time but im a little confused about the role of "daylight saving time". My zone is the UTC/GMT +2 hours and the daylight saving time +1. Does the ios count the sum or only the +2. What the timezone should be? +2 or +3 ?
thanks
Edison Ortiz
You first need to enter the command:
clock timezone EET +2
http://www.cisco.com/en/US/docs/ios/netmgmt/command/reference/nm_03.html#wp1013950
Followed by the command:
clock summer-time EEST recurring
http://www.cisco.com/en/US/docs/ios/netmgmt/command/reference/nm_03.html#wp1013813
You are able to change the start and end date for the summer-time with the above command as well. All this information is explained in the links I've provided.
HTH,
__
Edison.
Edison Ortiz
HTH,
__
Edison.
