Configuring traffic limit on 3560
I have an 24 port 3560G which i want to use to limit per port the throughput (input and output).
For example,
Port 1: 300mbit up (from CPE to switch) and 100mbit down
Port 2: 400mbit up (from CPE to switch) and 200mbit down
Port 3: 500mbit up (from CPE to switch) and 400mbit down
Port 4: full (no limit) that is the easy one.
I have looked at different configs and could not find the correct one.
Any pointers ?
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
On a 3560G you can configure a service police to police ingress rates.  You can also activate QoS and shape, per port, egress queues.
Look at the chapter in the user guide, for your IOS version, about QoS features.
Hi Joseph,
Do you have any example configs, or a direct link to some examples ?
Martin
Disclaimer
Posting
Likely, the examples on Cisco's main site are better than what I would post.
BTW, you'll find more examples under "3750", the 3560's sibling (except for the 3750s stacking, they are just about identical).
