Configuring VLANs
ronin2307
I am very new to Cisco hardware and VLANs in general. We have a very simple network setup (ASA5510 set up as a router/firewall and many switched of which I am only trying to deal with a Cisco Catalyst 2960).
WHat I was hoping to do without any additional wiring is to add a VLAN for an AP that would be used for guest access to the internet, but not the internal network.
So on the ASA i created a subinterface off of the main inside interface and on the 2960 I created a new VLAN. Then i tried to configure the port on the 2960 to which the ASA is connected as a trunk port, but at that moment everybody loses the connection to the outside.
Basically, where can i find any documentation on how to properly set this up with the hardware I have.
I am sure i am missing many things, but I do need some guidance.
Thank you
40 Replies 40
Weird.
CISCO-COLO# config t
CISCO-COLO(config)# int Ethernet 0/3
CISCO-COLO(config-if)# switchport ?
interface mode commands/options:
access Set access mode characteristics of the interface
mode Set trunking mode of the interface
monitor Monitor another interface
protected Configure an interface to be a protected port
trunk Set trunking characteristics of the interface
Also remove the nameif from E0/2
interface Ethernet0/2
description Trunk Only!!!! DO NOT CONFIGURE
speed 100
duplex full
no ip address
switchport mode trunk
switchport trunk allowed vlan 200
Hawkeye-ASA5510# config t
Hawkeye-ASA5510(config)# int eth 0/2
Hawkeye-ASA5510(config-if)# switchport
ERROR: % Invalid input detected at '^' marker.
Hawkeye-ASA5510(config-if)# switchport ?
ERROR: % Unrecognized command
Was this port configured with nameif before you upgraded to 8.x? Normally you can only assign nameif to VLANs.
the port was disabled since the beginning. I just as recently as last week enabled it and started playing with the vlans
Can you remove the nameif?
already did, but i dont see why that would make any difference
nameif implies a security zone, we want a switch/trunk port. Still no switchport under the physical interface?
still nothing :-(
latest and the greatest 8.0.3
Result of the command: "show interface"
Interface Ethernet0/1 "inside", is up, line protocol is up
Hardware is i82546GB rev03, BW 1000 Mbps, DLY 10 usec
Full-Duplex(Full-duplex), 100 Mbps(100 Mbps)
MAC address 0012.d948.f617, MTU 1500
IP address 192.168.1.XXX, subnet mask 255.255.255.0
3377797 packets input, 1409435170 bytes, 0 no buffer
Received 165455 broadcasts, 0 runts, 0 giants
0 input errors, 13719 CRC, 0 frame, 0 overrun, 13719 ignored, 0 abort
0 L2 decode drops
4746865 packets output, 2385992427 bytes, 0 underruns
0 babbles, 0 late collisions, 0 deferred
0 lost carrier, 0 no carrier
input queue (curr/max packets): hardware (0/30) software (0/0)
output queue (curr/max packets): hardware (0/53) software (0/0)
Traffic Statistics for "inside":
3377584 packets input, 1341678780 bytes
4746865 packets output, 2296225116 bytes
73578 packets dropped
1 minute input rate 74 pkts/sec, 5958 bytes/sec
1 minute output rate 135 pkts/sec, 56821 bytes/sec
1 minute drop rate, 0 pkts/sec
5 minute input rate 67 pkts/sec, 40605 bytes/sec
5 minute output rate 83 pkts/sec, 31588 bytes/sec
5 minute drop rate, 1 pkts/sec
Interface Ethernet0/2 "dmz", is up, line protocol is up
Hardware is i82546GB rev03, BW 100 Mbps, DLY 100 usec
Description: Trunk Only!!!! DO NOT CONFIGURE
MAC address 0012.d948.f618, MTU 1500
IP address unassigned
59 packets input, 5374 bytes, 0 no buffer
Received 59 broadcasts, 0 runts, 0 giants
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
0 L2 decode drops
1 packets output, 64 bytes, 0 underruns
input queue (curr/max packets): hardware (5/9) software (0/0)
output queue (curr/max packets): hardware (0/1) software (0/0)
Traffic Statistics for "dmz":
59 packets input, 4312 bytes
0 packets output, 0 bytes
22 packets dropped
1 minute input rate 0 pkts/sec, 0 bytes/sec
1 minute output rate 0 pkts/sec, 0 bytes/sec
5 minute input rate 0 pkts/sec, 0 bytes/sec
5 minute output rate 0 pkts/sec, 0 bytes/sec
5 minute drop rate, 0 pkts/sec
Interface Ethernet0/2.200 "WIFI", is up, line protocol is up
VLAN identifier 200
Description: WiFi DMZ
IP address 192.168.2.1, subnet mask 255.255.255.0
Traffic Statistics for "WIFI":
0 packets input, 0 bytes
1 packets output, 28 bytes
0 packets dropped
Interface Ethernet0/3 "", is administratively down, line protocol is down
Auto-Duplex, Auto-Speed
Available but not configured via nameif
MAC address 0012.d948.f619, MTU not set
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants
0 L2 decode drops
0 packets output, 0 bytes, 0 underruns
input queue (curr/max packets): hardware (0/0) software (0/0)
output queue (curr/max packets): hardware (0/0) software (0/0)
We found out (config guide) that the ASA only supports trunking with the Security Plus license.
