configuring wired 802.1x with Cisco 2950 and NPS 2012 problem
onurtanriverdi
I am trying to setup wired authentication on my corporate network. For testing purposes, I have setup a Cisco 2950 switch for RADIUS authentication.
On the first day of the test, access messages were appearing on the event log of the 2012 Server and  we were trying to address the issues with EAP and policy.(Network Policy and Access services)
Then, suddenly no events are written to the event log for the wired authentication. Accounting data is written to the log file at c:\windows\system32\logfiles, but nothing happens on the event log as if the NPS is not answering. We are using the same server for wireless 802.1x and all is working fine.
Checking the wired autoconfig log on the client, Restart Reason : Onex Auth Timeout appears.
Logging seems to be configured properly, there are no entries in event log. Below is the debug information from the 2950 switch;
KAT2-BATISW1#
00:18:28: dot1x-registry:dot1x_port_linkchange invoked on interface FastEthernet
0/17
00:18:28: dot1x-registry:dot1x_port_linkcomingup invoked on interface FastEthern
et0/17
00:18:28: dot1x-ev:dot1x_port_enable: set dot1x ask handler on interface FastEth
ernet0/17
00:18:28: dot1x-ev:dot1x_update_port_direction: Updating oper direction for Fa0/
17 (admin=Both, current oper=Both)
00:18:28: dot1x-ev:dot1x_update_port_direction: New oper direction for Fa0/17 is
 Both
00:18:28:     dot1x_auth Fa0/17: initial state auth_initialize has enter
00:18:28: dot1x-sm:Fa0/17:0000.0000.0000:auth_initialize_enter called
00:18:28: dot1x-ev:auth_initialize_enter:0000.0000.0000: Current ID=0
00:18:28:     dot1x_auth Fa0/17: during state auth_initialize, got event 0(cfg_a
uto)
00:18:28: @@@ dot1x_auth Fa0/17: auth_initialize -> auth_disconnected
00:18:28: dot1x-sm:Fa0/17:0000.0000.0000:auth_disconnected_enter_action called
00:18:28: dot1x-sm:
dot1x_update_port_status called with port_status = DOT1X_PORT_STATUS_UNAUTHORIZE
D
 Both
00:18:28: dot1x-ev:dot1x_port_cleanup_author: cleanup author on interface FastEt
hernet0/17
00:18:28: dot1x-ev:dot1x_update_port_status: Called with host_mode=0 state UNAUT
HORIZED
00:18:28: dot1x-ev:dot1x_update_port_status: using mac 0000.0000.0000 to send po
rt to unauthorized on vlan 0
00:18:28: dot1x-ev:Found a supplicant block for mac 0000.0000.0000 80D71C74
00:18:28: dot1x-ev:dot1x_port_unauthorized: Host-mode=0 radius/guest vlan=0 on F
astEthernet0/17
00:18:28: dot1x-ev:    GuestVlan configured=0
00:18:28: dot1x-ev:supplicant 0000.0000.0000 is default
00:18:28: dot1x-ev:supplicant 0000.0000.0000 is last
00:18:28: dot1x-ev:0000.0000.0000 is now unauthorized on port FastEthernet0/17
hernet0/17
00:18:28: dot1x-ev:Enter function dot1x_aaa_acct_end
00:18:28:     dot1x_auth Fa0/17: idle during state auth_disconnected
00:18:28: @@@ dot1x_auth Fa0/17: auth_disconnected -> auth_connecting
00:18:28: dot1x-sm:Fa0/17:0000.0000.0000:auth_connecting_enter called
00:18:28:     dot1x_bend Fa0/17: initial state dot1x_bend_initialize has enter
00:18:28: dot1x-sm:Dot1x Initialize State Entered
00:18:28:     dot1x_bend Fa0/17: initial state dot1x_bend_initialize has idle
00:18:28:     dot1x_bend Fa0/17: during state dot1x_bend_initialize, got event 1
6383(idle)
00:18:28: @@@ dot1x_bend Fa0/17: dot1x_bend_initialize -> dot1x_bend_idle
00:18:28: dot1x-sm:Dot1x Idle State Entered
00:18:28: dot1x-ev:Created port supplicant block 0000.0000.0000 expected_id=0 cu
rrent_id=0
00:18:28: dot1x-ev:dot1x_init_sb_oper_info:Default port supplicant at memloc 80D
71C74
00:18:28: dot1x-ev:dot1x_post_message_to_auth_sm: cleanup author from interface
FastEthernet0/17
00:18:28: dot1x-ev:
dot1x_post_message_to_auth_sm:0000.0000.0000: Sending TX_FAIL
00:18:28: dot1x-ev:dot1x_post_message_to_auth_sm:0000.0000.0000: Current ID=1
00:18:28: dot1x-ev:Transmitting an EAPOL frame on FastEthernet0/17
00:18:28: dot1x-packet:Tx EAP-Failure, id 0, ver 1, len 4 (Fa0/17)
00:18:28: dot1x-registry:registry:dot1x_ether_macaddr called
00:18:28: dot1x-packet:Tx sa=000f.24e9.72d1, da=0180.c200.0003, et 888E (Fa0/17)
FastEthernet0/17
00:18:28: dot1x-ev:dot1x_post_message_to_auth_sm: Tx for req_id for supplicant 0
000.0000.0000
00:18:28: dot1x-packet:Tx EAP-Request(Id), id 1, ver 1, len 5 (Fa0/17)
00:18:28: dot1x-ev:Received an EAPOL frame on interface FastEthernet0/17
00:18:28: dot1x-packet:Rx EAP-Response(Id), id 1, ver 1, len 21 (Fa0/17)
00:18:28: dot1x-packet:Rx sa=0024.1d10.d7c5, da=0180.c200.0003, et 888E (Fa0/17)
00:18:28: dot1x-ev:Couldn't find a supplicant block for mac 0024.1d10.d7c5
00:18:28: dot1x-sm:Fa0/17:0024.1d10.d7c5:auth_initialize_enter called
00:18:28: dot1x-ev:auth_initialize_enter:0024.1d10.d7c5: Current ID=0
uto)
00:18:28: dot1x-sm:Fa0/17:0024.1d10.d7c5:auth_disconnected_enter_action called
00:18:28: dot1x-sm:
D
 Both
hernet0/17
HORIZED
00:18:28: dot1x-ev:dot1x_update_port_status: using mac 0024.1d10.d7c5 to send po
00:18:28: dot1x-ev:Found a supplicant block for mac 0024.1d10.d7c5 80D7E584
astEthernet0/17
00:18:28: dot1x-ev:supplicant 0024.1d10.d7c5 is last
00:18:28: dot1x-ev:0024.1d10.d7c5 is now unauthorized on port FastEthernet0/17
hernet0/17
00:18:28: dot1x-sm:Fa0/17:0024.1d10.d7c5:auth_connecting_enter called
6383(idle)
00:18:28: dot1x-ev:Created port supplicant block 0024.1d10.d7c5 expected_id=1 cu
rrent_id=1
FastEthernet0/17
FastEthernet0/17
024.1d10.d7c5
00:18:28: dot1x-packet:Tx EAP-Request(Id), id 0, ver 1, len 5 (Fa0/17)
00:18:28: dot1x-packet:Rx EAP-Response(Id), id 0, ver 1, len 21 (Fa0/17)
00:18:28:     dot1x_auth Fa0/17: during state auth_connecting, got event 7(rxRes
pId)
00:18:28: @@@ dot1x_auth Fa0/17: auth_connecting -> auth_authenticating
00:18:28: dot1x-sm:Fa0/17:0024.1d10.d7c5:auth_connecting_exit alled
00:18:28: dot1x-sm:Fa0/17:0024.1d10.d7c5:auth_authenticating_enter called
00:18:28: dot1x-ev:sending AUTH_START to BEND for supp_info=80D7E584
00:18:28: dot1x-sm:Fa0/17:0024.1d10.d7c5:auth_connecting_authenticating_action c
alled
00:18:28: dot1x-ev:Received AuthStart from Authenticator for supp_info=80D7E584
00:18:28:     dot1x_bend Fa0/17: during state dot1x_bend_idle, got event 1(auth_
start)
00:18:28: @@@ dot1x_bend Fa0/17: dot1x_bend_idle -> dot1x_bend_response
00:18:28: dot1x-sm:Dot1x Response State Entered for supp_info=80D7E584 hwidb=807
D353C, swidb=807D4898 on intf=Fa0/17
00:18:28: dot1x-ev:Managed Timer in sub-block attached as leaf to master
00:18:28: dot1x-sm:Started the ServerTimeout Timer
00:18:28: dot1x-ev:Going to Send Request to AAA Client on RP for id = 0 and leng
th = 21
00:18:28: dot1x-ev:Got a Request from SP to send it to Radius with id 4294967283
00:18:28: dot1x-ev:Couldn't Find a process thats already handling the request fo
r this id 0
00:18:28: dot1x-ev:Inserted AAA request for interface FastEthernet0/17, MAC 0024
.1d10.d7c5, VLAN 0 on pending request queue
00:18:28: dot1x-ev:Found a free slot at slot 0
00:18:28: dot1x-ev:Processing AAA request for interface FastEthernet0/17, MAC 00
24.1d10.d7c5, VLAN 0 from pending request queue
00:18:28: dot1x-ev:Request id = -13 and length = 21
00:18:28: dot1x-ev:The Interface on which we got this AAA Request is FastEtherne
t0/17
00:18:28: dot1x-ev:Username is DUZEY\SAYTAMANER
00:18:28: dot1x-ev:MAC Address is 0024.1d10.d7c5
00:18:28: dot1x-ev:RemAddr is 00-24-1D-10-D7-C5/00-0F-24-E9-72-D1
00:18:30: %LINK-3-UPDOWN: Interface FastEthernet0/17, changed state to up
00:18:46: dot1x-ev:Received an EAPOL frame on interface FastEthernet0/17
00:18:46: dot1x-packet:Rx EAPOL-Start, ver 1, len 0 (Fa0/17)
00:18:46: dot1x-packet:Rx sa=0024.1d10.d7c5, da=0180.c200.0003, et 888E (Fa0/17)
00:18:46: dot1x-ev:Found a supplicant block for mac 0024.1d10.d7c5 80D7E584
00:18:46: dot1x-ev:RECEIVED mac =0024.1d10.d7c5 and Stored MAC =0024.1d10.d7c5
00:18:46:     dot1x_auth Fa0/17: during state auth_authenticating, got event 4(e
apStart)
00:18:46: @@@ dot1x_auth Fa0/17: auth_authenticating -> auth_aborting
00:18:46: dot1x-sm:Fa0/17:0024.1d10.d7c5:auth_aborting_enter called
00:18:46: dot1x-sm:Fa0/17:0024.1d10.d7c5:auth_authenticating_aborting_action cal
led
00:18:46: dot1x-ev:Received DOT1X_MSG_AUTH_ABORT: setting msg_id = 0
00:18:46:     dot1x_bend Fa0/17: during state dot1x_bend_response, got event 5(i
nitialize)
00:18:46: @@@ dot1x_bend Fa0/17: dot1x_bend_response -> dot1x_bend_initialize
00:18:46: dot1x-sm:Dot1x Initialize State Entered
00:18:46:     dot1x_bend Fa0/17: idle during state dot1x_bend_initialize
00:18:46: @@@ dot1x_bend Fa0/17: dot1x_bend_initialize -> dot1x_bend_idle
00:18:46: dot1x-sm:Dot1x Idle State Entered
00:18:46:     dot1x_auth Fa0/17: during state auth_aborting, got event 16(noauth
Abort_noeapLogoff)
00:18:46: @@@ dot1x_auth Fa0/17: auth_aborting -> auth_connecting
00:18:46: dot1x-sm:Fa0/17:0024.1d10.d7c5:auth_connecting_enter called
00:18:46: dot1x-ev:dot1x_post_message_to_auth_sm: Tx for req_id for supplicant 0
024.1d10.d7c5
00:18:46: dot1x-ev:Transmitting an EAPOL frame on FastEthernet0/17
00:18:46: dot1x-packet:Tx EAP-Request(Id), id 1, ver 1, len 5 (Fa0/17)
00:18:46: dot1x-registry:registry:dot1x_ether_macaddr called
00:18:46: dot1x-packet:Tx sa=000f.24e9.72d1, da=0180.c200.0003, et 888E (Fa0/17)
00:18:46: dot1x-packet:Rx EAP-Response(Id), id 1, ver 1, len 21 (Fa0/17)
00:18:46:     dot1x_auth Fa0/17: during state auth_connecting, got event 7(rxRes
pId)
00:18:46: @@@ dot1x_auth Fa0/17: auth_connecting -> auth_authenticating
00:18:46: dot1x-sm:Fa0/17:0024.1d10.d7c5:auth_connecting_exit alled
00:18:46: dot1x-sm:Fa0/17:0024.1d10.d7c5:auth_authenticating_enter called
00:18:46: dot1x-ev:sending AUTH_START to BEND for supp_info=80D7E584
00:18:46: dot1x-sm:Fa0/17:0024.1d10.d7c5:auth_connecting_authenticating_action c
alled
00:18:46: dot1x-ev:Received AuthStart from Authenticator for supp_info=80D7E584
00:18:46:     dot1x_bend Fa0/17: during state dot1x_bend_idle, got event 1(auth_
start)
00:18:46: @@@ dot1x_bend Fa0/17: dot1x_bend_idle -> dot1x_bend_response
00:18:46: dot1x-sm:Dot1x Response State Entered for supp_info=80D7E584 hwidb=807
00:18:46: dot1x-ev:Managed Timer in sub-block attached as leaf to master
00:18:46: dot1x-sm:Started the ServerTimeout Timer
00:18:46: dot1x-ev:Going to Send Request to AAA Client on RP for id = 1 and leng
th = 21
00:18:46: dot1x-ev:Got a Request from SP to send it to Radius with id 4294967284
00:18:46: dot1x-ev:Found a process thats already handling therequest for this id
00:18:48: dot1x-err:Dot1x Authentication failed (AAA_AUTHEN_STATUS_ERROR)
00:18:48: dot1x-ev:Received VLAN is No Vlan
00:18:48: dot1x-ev:Enqueued the response to BackEnd
00:18:48: dot1x-ev:Found a supplicant block for mac 0024.1d10.d7c5 80D7E584
00:18:48: dot1x-ev:Enter function dot1x_aaa_acct_end
00:18:48: dot1x-ev:Received QUEUE EVENT in response to AAA Request
00:18:58: dot1x-sm:Fa0/17:0000.0000.0000:dot1x_process_txWhen_expire called
00:18:58:     dot1x_auth Fa0/17: during state auth_connecting, got event 19(txWh
en_expire)
00:18:58: @@@ dot1x_auth Fa0/17: auth_connecting -> auth_connecting
00:18:58: dot1x-sm:Fa0/17:0000.0000.0000:auth_connecting_connecting_action calle
d
00:18:58: dot1x-ev:dot1x_post_message_to_auth_sm: Skipping tx for req_id for def
ault supplicant
00:19:07: dot1x-ev:Received an EAPOL frame on interface FastEthernet0/17
00:19:07: dot1x-packet:Rx EAPOL-Start, ver 1, len 0 (Fa0/17)
00:19:07: dot1x-packet:Rx sa=0024.1d10.d7c5, da=0180.c200.0003, et 888E (Fa0/17)
00:19:07: dot1x-ev:Found a supplicant block for mac 0024.1d10.d7c5 80D7E584
00:19:07: dot1x-ev:RECEIVED mac =0024.1d10.d7c5 and Stored MAC =0024.1d10.d7c5
00:19:07:     dot1x_auth Fa0/17: during state auth_authenticating, got event 4(e
apStart)
00:19:07: @@@ dot1x_auth Fa0/17: auth_authenticating -> auth_aborting
00:19:07: dot1x-sm:Fa0/17:0024.1d10.d7c5:auth_aborting_enter called
00:19:07: dot1x-sm:Fa0/17:0024.1d10.d7c5:auth_authenticating_aborting_action cal
led
00:19:07: dot1x-ev:Received DOT1X_MSG_AUTH_ABORT: setting msg_id = 0
00:19:07:     dot1x_bend Fa0/17: during state dot1x_bend_response, got event 5(i
nitialize)
00:19:07: @@@ dot1x_bend Fa0/17: dot1x_bend_response -> dot1x_bend_initialize
00:19:07: dot1x-sm:Dot1x Initialize State Entered
00:19:07:     dot1x_bend Fa0/17: idle during state dot1x_bend_initialize
00:19:07: @@@ dot1x_bend Fa0/17: dot1x_bend_initialize -> dot1x_bend_idle
00:19:07: dot1x-sm:Dot1x Idle State Entered
00:19:07:     dot1x_auth Fa0/17: during state auth_aborting, got event 16(noauth
Abort_noeapLogoff)
00:19:07: @@@ dot1x_auth Fa0/17: auth_aborting -> auth_connecting
00:19:07: dot1x-sm:Fa0/17:0024.1d10.d7c5:auth_connecting_enter called
00:19:07: dot1x-ev:dot1x_post_message_to_auth_sm: Tx for req_id for supplicant 0
024.1d10.d7c5
00:19:07: dot1x-ev:Transmitting an EAPOL frame on FastEthernet0/17
00:19:07: dot1x-packet:Tx EAP-Request(Id), id 2, ver 1, len 5 (Fa0/17)
00:19:07: dot1x-registry:registry:dot1x_ether_macaddr called
00:19:07: dot1x-packet:Tx sa=000f.24e9.72d1, da=0180.c200.0003, et 888E (Fa0/17)
00:19:07: dot1x-packet:Rx EAP-Response(Id), id 2, ver 1, len 21 (Fa0/17)
00:19:07:     dot1x_auth Fa0/17: during state auth_connecting, got event 7(rxRes
pId)
00:19:07: @@@ dot1x_auth Fa0/17: auth_connecting -> auth_authenticating
00:19:07: dot1x-sm:Fa0/17:0024.1d10.d7c5:auth_connecting_exit alled
00:19:07: dot1x-sm:Fa0/17:0024.1d10.d7c5:auth_authenticating_enter called
00:19:07: dot1x-ev:sending AUTH_START to BEND for supp_info=80D7E584
00:19:07: dot1x-sm:Fa0/17:0024.1d10.d7c5:auth_connecting_authenticating_action c
alled
00:19:07: dot1x-ev:Received AuthStart from Authenticator for supp_info=80D7E584
00:19:07:     dot1x_bend Fa0/17: during state dot1x_bend_idle, got event 1(auth_
start)
00:19:07: @@@ dot1x_bend Fa0/17: dot1x_bend_idle -> dot1x_bend_response
00:19:07: dot1x-sm:Dot1x Response State Entered for supp_info=80D7E584 hwidb=807
00:19:07: dot1x-ev:Managed Timer in sub-block attached as leaf to master
00:19:07: dot1x-sm:Started the ServerTimeout Timer
00:19:07: dot1x-ev:Going to Send Request to AAA Client on RP for id = 2 and leng
th = 21
00:19:07: dot1x-ev:Got a Request from SP to send it to Radius with id 4294967285
00:19:07: dot1x-ev:Couldn't Find a process thats already handling the request fo
r this id 2
00:19:07: dot1x-ev:Inserted AAA request for interface FastEthernet0/17, MAC 0024
00:19:07: dot1x-ev:Found a free slot at slot 0
00:19:07: dot1x-ev:Processing AAA request for interface FastEthernet0/17, MAC 00
00:19:07: dot1x-ev:Request id = -11 and length = 21
00:19:07: dot1x-ev:The Interface on which we got this AAA Request is FastEtherne
t0/17
00:19:07: dot1x-ev:Username is DUZEY\SAYTAMANER
00:19:07: dot1x-ev:MAC Address is 0024.1d10.d7c5
00:19:07: dot1x-ev:RemAddr is 00-24-1D-10-D7-C5/00-0F-24-E9-72-D1
00:19:19: dot1x-registry:dot1x_port_linkchange invoked on interface FastEthernet
0/17
00:19:19: dot1x-ev:supp_info=80D7E584 txWhen_timer=80D7E5D4 quietWhile_timer=80D
7E594reAuthWhen_timer=80D7E5B4 awhile_timer=80D7E5F4
00:19:19: dot1x-ev:destroy supplicant block for 0024.1d10.d7c5
00:19:19: dot1x-ev:supp_info=80D71C74 txWhen_timer=80D71CC4 quietWhile_timer=80D
71C84reAuthWhen_timer=80D71CA4 awhile_timer=80D71CE4
00:19:19: dot1x-ev:destroy supplicant block for 0000.0000.0000
00:19:19: dot1x-ev:Enter function dot1x_aaa_acct_end
00:19:19: dot1x-ev:Found a supplicant block for mac 0000.0000.0000 80D71C74
00:19:19: dot1x-ev:dot1x_port_cleanup_author: cleanup author on interface FastEt
hernet0/17
00:19:19: dot1x-ev:dot1x_post_message_to_auth_sm: cleanup author from interface
This is driving me crazy, working on it for a whole week and no results..
Thank you..
Leo Laohoo
2950 does NOT fully support 802.1x.  Full 802.1x support starts with 2960.
5 Replies 5
Leo Laohoo
Thank you. We have a 2960 for testing purposes, going to test the same setup with it and post the results. What I am trying to do is only authentication, NAP is not important.
Hi again,
I have put the config on 2960. Now as soon as the authentication starts, this is the message on debug;
dot1x authentication unable to start - authenticator not enabled..
Any ideas?
regards,
onur
Got it working... 2960 is working great.
Thanks again.
EDIT: For those wondering what my solution was, I was missing (global config):
  • dot1x system-auth-control
So uh, mind sharing the solution? Having the same problem here.
