Confirming CLI commands before copying?
cliffordr2000
Community Member
              Hi All,
                   Is there a way to confirm the cli commands inputted into a Nexus5k (NX-OS) Ver 4.1(3) N1(1), before copying it to start. The JunOS has a "commit check" command that will give a heads up if the commands you are about to put in are going to hose your network. The "checkpoint" function will get me back to an operational state, but, I would rather not have to dance while the network comes back to life.
Thanks All,
              Ron Clifford
3 Accepted Solutions
Hello
Cisco also have a rollback back feature.This is initiated using the archive command
Once setup it will rollback any applied config if it isn't confirmed within a specified time period- I personally think it better than a schedule reload
However on certain iOS and hardware eg 6509-6513's iI have found it seems to not work as it should also am not aware of any cisco feature that will test your config is good prior to implementing as junos does.
Res
Paul
Kind Regards
Paul
IOS-XR implements the commit feature and checks the validity of the config and it seems NX-OS does the same
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus5000/sw/configuration/guide/cli_rel_4_0_1a/CLIConfigurationGuide/sm_rollback.html#wp1076261
Alain
Reza Sharifi
Hi Ron,
unfortunately, commit check, rollback 1,2, 3, etc... are all part of Junos and not IOS or Nexus OS. With Nexus OS, as soon as you type a command and press enter, it will take effect just like the regular IOS.
Cisco is trying to add great features that Juniper has, but they still have a long way to go, because they have too many different OSs.
Hello
Res
Paul
Kind Regards
Paul
Alain
Reza Sharifi
Hi Ron,
