confused between Stack & VSS
vvvvvbbb123
Hi Guys,
I am confused to know the difference between VSS and stacking. I seem both to be similar expect in terms of the hardware and software requirement.
I mean they both operate similar. Could anyone explain the difference between these two ?
VB
Leo Laohoo
VSS is composed of two chassis (4500, 6800 or 6500).
Stacking are mostly composed of Catalyst 2K and 3K switches and you can stack up to 9 switches (of the same model) to form a single (logical) switch stack.
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
They both allow multiple physical devices to operate as one logical device.  VSS only supports "pairs" while stackable switches support multiple units; currently, I believe all now support up to 9 units (as also mentioned by Leo).  The stackable switches generally use special modules and cables, and need to be very close together, physically.  VSS uses "ordinary" Ethernet connections, and can be spread miles and miles apart (although they are usually near each other).
There are subtle differences in how they actually operate.  For example, VSS may try to avoid using the links that connect the pair while stacked switches don't avoid using their stack connection.
Hardware and software requirements vary.  For example, in the 6500 series, only certain sups support VSS, and when running in VSS mode, only certain line cards are supported.  On the 3750s, stack ports and cables are "standard" but on the 2960S stackables, special modules need to be added.
devils_advocate
Level 7
Level 7
I won't describe the differences as Joseph and Leo have covered it but having tried to use 8 switches in a single stack, the console is was almost unresponsive.
5 would be my maximum from personal experience but each to their own :)
