Confused remembering different Cisco Switches and Routers Models Numbers
rizwpate
I am always confused about what different cisco router and switch model numbers are out there and how are they different. Is there a way to tell a specific model number is a router or a switch or you just remember it over time ?
Latchum Naidu
I would suggest to maintain a asset inventory of all network devices.
Please rate the helpfull posts.
Naidu.
Thanks Naidu for your quick response
rizwpate
Actully i have found an answer to my question and would like to share it with you guys.
This site provides all the information you need on all kinds of Cisco Products :
http://www.router-switch.com/Price-cisco-switches_c2
I hope it helps someone looking for similar information ....
