Congestion detection on physical interface for queuing
sarahr202
Level 7
Level 7
Hi everybody,
http://lostintransit.se/category/qos/
According to above congestion is detected when:
QoS is only active during congestion. This is well known but it’s not as well known how congestion is detected. the TX ring is used to hold packets before they get transmitted out on an interface. This is a hardware FIFO queue and when the queue gets filled, the interface is congested.
I decided to lab it up:
R1--199.199.199.0--R2 f0/1--200.200.200.0--R3 ( Lo:3.3.3.3)
Above R1 will generate "interesting traffic" by pinging 3.3.3.3 , on R2 we define a class LEE for all traffic sourced from 199.199.199.1( R1) and destined to 3.3.3.3 ( R3)
This class is given 75% of f0/0' bandwidth.
R2#show policy-map interface f0/1
FastEthernet0/1
Service-policy output: LEE
Class-map: LEE (match-all)
0 packets, 0 bytes
5 minute offered rate 0 bps, drop rate 0 bps
Match: access-group 101
police:
rate 75 %
rate 75000000 bps, burst 2343750 bytes
conformed 0 packets, 0 bytes; actions:
transmit
exceeded 0 packets, 0 bytes; actions:
drop
conformed 0 bps, exceed 0 bps
Class-map: class-default (match-any)
3 packets, 214 bytes
Match: any
Next , we are going to generate traffic from R1 to 3.3.3.3
R1#ping 3.3.3.3
Sending 5, 100-byte ICMP Echos to 3.3.3.3, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 12/19/24 ms
FastEthernet0/1
5 packets, 570 bytes
police:
rate 75 %
conformed 5 packets, 570 bytes; actions:
transmit
drop
26 packets, 2282 bytes
Match: any
1) How do we interpret " conformed 5 packets" above?  Should we say there is congestion on R2's f0/1  based on this ? If yes , how , because there is very little traffic exiting  f0/1 , just  5 pings ?
2) Are those 5 packets  queued in class LEE? If yes, then why,  because there is no congestion on f0/1 on R2?
On the other hand if I modify Class LEE as priority, I see following:
R2(config)#policy-map LEE
R2(config-pmap)#no class LEE
R2(config-pmap)#class LEE
R2(config-pmap-c)#priority  percent 75
R2#clear counters
Next we generate pings to 3.3.3.3 from R1
R1#ping 3.3.3.3
FastEthernet0/1
Queueing
Strict Priority
Output Queue: Conversation 264
Bandwidth 75 (%)
Bandwidth 75000 (kbps) Burst 1875000 (Bytes)
(pkts matched/bytes matched) 0/0
(total drops/bytes drops) 0/0
Above we see none of the counters increment .  To put it simply, should " conformed packets" counter be interpreted as indication of congestion  or a just a counter showing conforming packets not congestion necessarily ?
Thanks and have a nice weekend.
Philip D'Ath
Meraki Community All-Star
Generally on routing platforms, QoS doesn't kick in until the hardware queue is filled up, and the software queue is being used.  It is the software queue that gets re-ordered.
On lower speed circuits it is common to have to reduce the size of the hardware queue to make QoS kick in sooner.
Philip D'Ath
