connect 2 x 3750X to dual-core collapsed core 6509 at layer 3 in order to reduce the MAC Table as the core reached 95% CAM Table
Ibrahim Jamil
Level 6
Level 6
Hello overseas Guys
Greeting
i got the below suggestion , but frankly confused me :(
mmmmm
what does it mean at layer 3 , does it mean the up links are L3 p2p or what ??
currently the routing happened for all SVIs + FHRP at both collapse 6509
7 Replies 7
Seb Rupik
Hi there,
Correct, logically you would configure a single Layer 3 link from the core. VLANs on the 3750 would be locally routed. This way the MAC addresses of devices connected to the 3750 do not appear in the core.
This implementation would be known as a routed access layer.
Keeping in mind that without additional licenses the 3750 does not support dynamic routing protocols so static routing would be required for the core, a default route would be sufficient on the access layer.
cheers,
Seb.
Leo Laohoo
This means the 3750X is Layer 3. Instead of the core switch keeping all the MAC address tables, this role has been "delegated" to the 3750X.
Hi Leo
so the interface from the 3750-X to core are P2P routed link , am i right
do i need to run EIGRP also on this 3750-X???
thanks
No need to run EIGRP on the 3750X. That job goes to the core switch.
Hello leo
did you consider the below
the links from 3750-X are p2p ( L3 Interfaces) to dual-core
thanks
If I remembered correctly, our core were running EIGRP and the 3750E were running OSPF. The core was re-distributing EIGRP to OSPF.
no no
only EIGRP at Collapsed CORE
thanks
