03-15-2007 07:54 AM - edited 03-05-2019 02:56 PM
Hi to all. I'm try to connect a Catalyst 6509 with a accelar 1050. In the Catalyst the interface has "Trunk Encapsulation dot1q" because this is a trunk interface, but I don't know how configure it in the accelar. Somebady has done this configuration and can help me? Or can help me in another way.
Thanks a lot.
Francisco Velasco
03-15-2007 12:22 PM
Francisco-
As far as I can remember, the 1050 doesn't support VLANs, so you wouldn't need trunking on the Accelar, and you could remove that statement from the Cisco uplink port. VLAN 1 info will still be available on the Accelar.
HTH,
Paul
03-20-2007 09:44 AM
OK Paul. I appreciate your help. That's correct your opinion, I going to do your suggest. Thanks again.
