Since you now have 2 vlans (1 and 100), the port that connects the 3560G to the Nighthawk router needs to be configured as trunk, which means the Nighthawk router port that connects to the 3560G also needs to be configured as trunk. The other issue is that the provider mostly likely is NATing only one subnet for you to use at home (wired and wireless) and not 2. So, whatever device is doing the NAT for the first subnet needs to be configured to do the same for the second subnet, which is vlan 100.
