Connect Cisco 3560 to home router and internet
swingr
Beginner
Beginner
I am guessing that this is a simple solution, but for some reason I am not searching the correct terms.
I have a consumer grade wifi/gig ethernet router (Netgear r7000) and I need to configure my Cisco Catalyst 3560 to connect to the router in order to allow internet access to all connected computers on the switch.
Netgear Router (r7000): 192.168.1.1 255.255.255.0
Default Gateway 192.168.1.1
Cisco 3560 Vlan1: 192.168.1.250 255.255.255.0
How do I configure a port to act as an "uplink" to the router? Thanks in advance!
John Blakley
Advisor
Advisor
Ryan,
You really shouldn't have to do anything special. Your router will be in vlan 1 along all of your other devices on the 192.168.1.0/24 subnet. Just connect your Netgear to port 1, for example, and you should see a link come up. If you don't see the link come up, try using a crossover cable (although I highly doubt this will be needed). There isn't a special uplink port like you see in soho switches you'd pick up at Best Buy.
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
Recognize Your Peers
