Connect cisco 3750X and Dell N4032F
Matias Perna
I need to connect 2 diferent networks (192.168.x.x vs 10.44.x.x). this connection will be temporal because network 192.168.x.x will be migrated to 10.44.x.x.
On one side I have a Dell N4032F (L3) and on the other side a Cisco 3750X. What I need is just visibility between them? Wich is the best way to do it.
Reza Sharifi
On the 3750X, you need to configure the IP address on the interface connecting to Dell.
example:
config t
interface gix/x
ip address 10.44.1.1 255.255.255.0
no sh
Not sure what you need on the Dell side.
Hi Reza,
From Dell side I need to access network 10.44.x.x just for visibility between networks. After that network 192.168.x.x will be migrated to 10.44.x.x
How should I configure interface port on DELL side??
