Connect Nexus 2332 to a 5672up
willsupport
Good Morning,
my customer bought those models of data center switches.
My questions is:
Cisco, for the 5672 provides an adapter that convert a qsfp 40g to a sfp 10g, so i can use my 10g optic modules on this switch.
Unfortunately on the 2332, this adapter is not compatible, and now i have a serious problem, cause i must use all the 40g ports to do redundant links but i won't have scalability for the future.
Can i connect the 40g port of the 2332 to the 10g port of the 5672, and be able to estabilish a link?
Alessandro
11 Replies 11
Reza Sharifi
The 2332 FEX comes only with 10Gig uplibks only? So, you would have go 10Gig to 10Gig.
the 2332 has 4x40g ports, i need to connect them to the 10g ports 5672up.
Could it work? 40g 2332tq -> 10g 5672up?
On the 2332tq i can't use that adapter.
The 5672up comes with 6 40Gig ports.  Can't just use 40 to 40 straight?
The topology is composed of:
- 2 5672UP
- 4 2332TQ
If i use redundant links between all the devices, i won't have free ports for future 2332 or others devices
- 2 5672UP
- 4 2332TQ
Even if you connect them fully meshed, you will still have 2 extra 40 gig in each 5672 to use in the feature.
Nope, i use all the ports on the 5672
I don't know but maybe you can use a 40GQSFP to four 10G SFP+ breakout cable...?
https://www.cisco.com/c/en/us/td/docs/interfaces_modules/transceiver_modules/compatibility/matrix/40GE_Tx_Matrix.pdf
It could be a solution, but the cable is only 10 meters long
I need to know if a 40g optic can communicate with a 10g optic.
