02-06-2015 02:18 AM - edited 03-07-2019 10:32 PM
Hi Gents,
I connected Nexus 3548 and Nexus 6001 with QSFP-4SFP10G-CU5M in between them with the aim of having 40GBASE-CR4 without success.
N3548: n3500-uk9.6.0.2.A1.1f.bin
N6001: n6000-uk9.6.0.2.N2.4.bin
N3548 release notes does not mention QSFP-4SFP10G-CU5M at all, but the datasheet says this:
Table 3. Cisco Nexus 3500 Platform 40 Gigabit Transceiver Support Matrix
Part Number | Description |
SFP-10G-SR | 10GBASE-SR SFP+ module (multimode fiber [MMF]) |
SFP-10G-LR | 10GBASE-LR SFP+ module (single-mode fiber [SMF]) |
QSFP-4SFP10G-CU1M | QSFP to 4 x SFP 10-Gbps passive copper splitter cable, 1m (Twinax cable) |
QSFP-4SFP10G-CU3M | QSFP to 4 x SFP 10-Gbps passive copper splitter cable, 3m (Twinax cable) |
QSFP-4SFP10G-CU5M | QSFP to 4 x SFP 10-Gbps passive copper splitter cable, 5m (Twinax cable) |
If someone is aware of the truth, please, let me know.
Kind regards,
Szilard
02-06-2015 10:28 AM
If you are trying to go between 2 switches using a 40Gig Twinax cable try this:
QSFP-H40G-CU5M
I have used it to connect Nexus 6ks together with no issues.
02-06-2015 12:46 PM
Hi Reza,
I believe the issue is not connecting two 6Ks its connecting a 3548 with a 6K. The 3548 has only 48x10G ports and the N6K has 48x10G and 4 QSFP port. According to Cisco's website it states that the 3548 can be logical configured for 40G (e.g (E1/-4 or E1/5-8, etc) using QSFP-4SFP10G-CU5M.
02-06-2015 12:53 PM
Ok, thanks for the clarification. I understand now. So the 3548 has only 10Gig ports and no 40G interfaces. That is why Szilard is trying to use QSFP-4SFP10G-CU5M cable.
So it appears that the 3548 switch does not have any uplink ports. Does that mean any other port can and should be used for uplinks?
05-30-2016 10:54 AM
Hi Team,
Can anyone suggest if N3548 support 10G classic transceivers (SFP-10G-LR-S=)?
Neeraj
