12-02-2019 04:38 AM
Is it recommended and considered as a validated design to connect a router or FWs to a 2K FEX connected to 9K Nexus switch?
The firewall will run OSPF with 9K switches that configured as a vPC.
Solved! Go to Solution.
12-02-2019 06:17 AM
If you are running 7.x layer-3 is supported. see table-1 in this link
It may also be simpler if you connect the router directly to the 9300 instead of the 2k.
12-02-2019 06:17 AM
