Connect two Catalyst 3750G
informatiquecns
I try to connect two switch Catalyst 3750G without success.
switch1 (192.168.2.10 vlan 2) <=> (192.168.2.11 vlan2) switch2
I use this configuration for swich1 :
enable
configure terminal
enable password MDP
end
copy running-config startup-config
configure terminal
hostname switch1
interface vlan 2
ip address 192.168.2.10 255.255.255.0
exit
ip default-gateway 192.168.2.252
end
configure terminal
vlan 2
name zone_client
end
configure Terminal
interface Gi1/0/3
switchport mode trunk
switchport nonegotiate
switchport trunk native vlan 2
switchport trunk allowed vlan 1,2,3,4
end
I use this configuration for swich2 :
enable
configure terminal
enable password MDP
end
configure terminal
hostname switch1
interface vlan 2
ip address 192.168.2.11 255.255.255.0
exit
end
configure terminal
vlan 2
name zone_client
end
configure Terminal
interface Gi1/0/3
end
when i use ping in console terminal, ping fail.
Somebody can help me?
3 Accepted Solutions
it didn't take the switchport mode trunk command because you configured it before switchport trunk encapsulation dot1q
so reenter this command switchport mode trunk and it should be good,  I still wonder how I didn't remark that before.
Regards.
Alain
    You need to add "switchport mode trunk" on Gi1/0/3 on both switches.
interface GigabitEthernet1/0/3
switchport trunk allowed vlan 1-4
HTH,
Toshi
PC<=>(Vlan 2 in access mode)switch1(vlan 2 in trunk mode)<=> (vlan in tagged mode ) HP swich <=> Gateway
If on sw1 Vlan 2 is the native vlan , it will be sent on the trunk untagged so it must be untagged also on the HP switch or you can force tagging of vlan 2( the native vlan) on the Cisco with the global config command: vlan dot1q tag native
Regards.
Alain
23 Replies 23
cadet alain
verify your vlan interface is up/up ---> sh ip int br | i Vlan
Regards.
Alain
Thank you cadet alain for your reply.
switch2>
switch2>enable
Password:
switch2#sh ip int br | i Vlan
Vlan1                  unassigned      YES unset  up                    up
Vlan2                  192.168.2.11    YES manual up                    down
switch2#
switch1>enable
Password:
switch1#sh ip int br | i Vlan
Vlan2                  192.168.2.10    YES manual up                    down
switch1#
I don't understand what is down. Can you explain?
what is the output of :
show vlan brief
sh spanning-tree vlan 2
Regards.
Alain
Vlan1                  unassigned      YES manual up                    up
switch1#show vlan brief
VLAN Name                             Status    Ports
1    default                          active    Gi1/0/1, Gi1/0/2, Gi1/0/3
                                                Gi1/0/4, Gi1/0/5, Gi1/0/6
                                                Gi1/0/7, Gi1/0/8, Gi1/0/9
                                                Gi1/0/10, Gi1/0/11, Gi1/0/12
                                                Gi1/0/13, Gi1/0/14, Gi1/0/15
                                                Gi1/0/16, Gi1/0/17, Gi1/0/18
                                                Gi1/0/19, Gi1/0/20, Gi1/0/21
                                                Gi1/0/22, Gi1/0/23, Gi1/0/24
                                                Gi1/0/25, Gi1/0/26, Gi1/0/27
                                                Gi1/0/28
2    zone_client                      active
1002 fddi-default                     act/unsup
1003 token-ring-default               act/unsup
1004 fddinet-default                  act/unsup
1005 trnet-default                    act/unsup
switch1#
switch1#sh spanning-tree vlan 2
Spanning tree instance(s) for vlan 2 does not exist.
switch1#
Gi1/0/3 doesn't seems in VLAN 2 but i don't know why...
    Please post "show interface trunk" on both switches.
Toshi
switch2#show interface trunk
switch1#show interface trunk
switch1#
(answer nothing )
    it's kinda weird.  Please post "show vtp status" and "show ip interface brief" on both switches.
Toshi
switch1#show vtp status
VTP Version                     : running VTP1 (VTP2 capable)
Configuration Revision          : 1
Maximum VLANs supported locally : 1005
Number of existing VLANs        : 6
VTP Operating Mode              : Server
VTP Domain Name                 :
VTP Pruning Mode                : Disabled
VTP V2 Mode                     : Disabled
VTP Traps Generation            : Disabled
MD5 digest                      : *************************************
Configuration last modified by 0.0.0.0 at 3-1-93 00:05:45
Local updater ID is 0.0.0.0 (no valid interface found)
switch1#
switch2>enable
Password:
Password:
switch2#show vtp status
VTP Domain Name                 :
Configuration last modified by 0.0.0.0 at 3-1-93 00:29:00
switch1#show ip interface brief
Interface              IP-Address      OK? Method Status                Protocol
GigabitEthernet1/0/1   unassigned      YES unset  down                  down
GigabitEthernet1/0/2   unassigned      YES unset  down                  down
GigabitEthernet1/0/3   unassigned      YES unset  up                    up
GigabitEthernet1/0/4   unassigned      YES unset  down                  down
GigabitEthernet1/0/5   unassigned      YES unset  down                  down
GigabitEthernet1/0/6   unassigned      YES unset  down                  down
GigabitEthernet1/0/7   unassigned      YES unset  down                  down
GigabitEthernet1/0/8   unassigned      YES unset  down                  down
GigabitEthernet1/0/9   unassigned      YES unset  down                  down
GigabitEthernet1/0/10  unassigned      YES unset  down                  down
GigabitEthernet1/0/11  unassigned      YES unset  down                  down
GigabitEthernet1/0/12  unassigned      YES unset  down                  down
GigabitEthernet1/0/13  unassigned      YES unset  down                  down
GigabitEthernet1/0/14  unassigned      YES unset  down                  down
GigabitEthernet1/0/15  unassigned      YES unset  down                  down
GigabitEthernet1/0/16  unassigned      YES unset  down                  down
GigabitEthernet1/0/17  unassigned      YES unset  down                  down
GigabitEthernet1/0/18  unassigned      YES unset  down                  down
GigabitEthernet1/0/19  unassigned      YES unset  down                  down
GigabitEthernet1/0/20  unassigned      YES unset  down                  down
GigabitEthernet1/0/21  unassigned      YES unset  down                  down
GigabitEthernet1/0/22  unassigned      YES unset  down                  down
GigabitEthernet1/0/23  unassigned      YES unset  down                  down
GigabitEthernet1/0/24  unassigned      YES unset  down                  down
GigabitEthernet1/0/25  unassigned      YES unset  down                  down
GigabitEthernet1/0/26  unassigned      YES unset  down                  down
GigabitEthernet1/0/27  unassigned      YES unset  down                  down
GigabitEthernet1/0/28  unassigned      YES unset  down                  down
switch1#
switch2#show ip interface brief
Hi Toshi,
He already posted the sh ip int br output and the vlan 2 interface was up/down
@ informatique cns: the vlan is active on switch 1 but it is not showing on g1/0/3 because this is a trunk
g1/0/3 is an access port in vlan 1 as sh vlan br outputs:
So as Toshi remarked and as your sh int trunk output proves there is something wrong with the trunk.
Can you do on both switches sh int g1/0/3 switchport and sh int g1/0/3 status and sh spanning-tree
@ Toshi by default VTP is OFF as Domain= null and if there is no trunk it can't anything
Regards.
Alain
switch2#sh int g1/0/3 switchport
Switchport: Enabled
Administrative Mode: dynamic auto
Operational Mode: static access
Administrative Trunking Encapsulation: dot1q
Operational Trunking Encapsulation: native
Negotiation of Trunking: On
Access Mode VLAN: 1 (default)
Trunking Native Mode VLAN: 2 (zone_client)
Administrative Native VLAN tagging: enabled
Voice VLAN: none
Administrative private-vlan host-association: none
Administrative private-vlan mapping: none
Administrative private-vlan trunk native VLAN: none
Administrative private-vlan trunk Native VLAN tagging: enabled
Administrative private-vlan trunk encapsulation: dot1q
Administrative private-vlan trunk normal VLANs: none
Administrative private-vlan trunk associations: none
Administrative private-vlan trunk mappings: none
Operational private-vlan: none
Trunking VLANs Enabled: 1-4
Pruning VLANs Enabled: 2-1001
Capture Mode Disabled
Capture VLANs Allowed: ALL
Protected: false
Unknown unicast blocked: disabled
Unknown multicast blocked: disabled
Appliance trust: none
switch1#
switch1#
switch1#sh int g1/0/3 switchport
Switchport: Enabled
Voice VLAN: none
Protected: false
switch1# sh int g1/0/3 status
Port      Name               Status       Vlan       Duplex  Speed Type
Gi1/0/3                      connected    1          a-full a-1000 10/100/1000BaseTX
switch1#
switch2# sh int g1/0/3 status
switch1# sh spanning-tree
VLAN0001
  Spanning tree enabled protocol ieee
  Root ID    Priority    32769
             Address     2c3f.3876.0200
             Cost        4
             Port        3 (GigabitEthernet1/0/3)
             Hello Time   2 sec  Max Age 20 sec  Forward Delay 15 sec
  Bridge ID  Priority    32769  (priority 32768 sys-id-ext 1)
             Address     68bc.0ceb.8200
             Aging Time  300 sec
Interface           Role Sts Cost      Prio.Nbr Type
Gi1/0/3             Root FWD 4         128.3    P2p
switch1#
switch2# sh spanning-tree
VLAN0001
             This bridge is the root
             Aging Time  300 sec
Gi1/0/3             Desg FWD 4         128.3    P2p
Hi Alain,
     Ahh, he alreay posted the outout of "show ip int brief" ;- ). I just want to make sure that there is nothing wrong with vtp mismatch its gonna break the trunk.
     It seems your port acting as access port.  Operational Mode: static access.
    Please post "show running".  To make sure that you correctly configured.
HTH,
Toshi
Hi Toshi,
Bu why are these access ports as he configured them as unconditional trunks ?
We only got sw2 output for sh int switchport but  there is something strange:
Is this the default to tag the native vlan ?  I don't think so
Can the OP post the same output for sw1.
Regards.
Alain
Hi Alian,
      It should not be a problem with changing native vlan.  I need to see the whole configuration. It has to be Operational Mode: trunk.
HTH,
Toshi
