05-21-2018 04:26 AM - edited 03-08-2019 03:05 PM
Hi everyone as in the project attached, I want the Network Administrator to communicate with all the computers. I can just do it with the computers in Switch 1, I can't get Network Administrator to ping the computers in Switch 2(right). Could you please check and offer solution ?
Thank you!
05-21-2018 04:32 AM
this looks like a Packet Tracer project, post the .pkt file (rename it to .jpg first, otherwise the system won't let you upload)...
05-21-2018 04:39 AM
05-21-2018 05:05 AM
05-21-2018 05:08 AM
there has to be a router connecting 2 switches. And all the vlans can communicate to each other.
The network administrator can ping all the computers.
05-21-2018 05:09 AM
Is the requirement to use the same address space on both switches ?
05-21-2018 05:16 AM
It doesn't say anything about that. Just use trunking, int vlan and encapsulation command. Here is the instruction file. I'm stuck at the last question at page 6.
"add a router between the two switches to allow all vlans to communicate with each other"
Thanks so much for your help.
05-21-2018 05:24 AM
05-21-2018 05:28 AM
is there any way we can keep the addresses?, because the requirement is like the figure in page 7.
05-21-2018 05:59 AM
You need to use bridging...
05-21-2018 06:36 AM
Could you please tell how to do that?
So we can't make the computers on the right switch connected just using concepts in the pdf file?
05-21-2018 10:23 AM
are you supposed to accomplish this task in Packet Tracer ? Packet Tracer has a very limited subset of commands, it does not support bridging.
05-21-2018 06:44 PM
yes i have to use packet tracer. But if there is no way to connect like this, so maybe the right computers can't get connected to the network using this topology. Because the question asks for what PC replies to Network Administrator?
