05-07-2013 02:06 PM - edited 03-07-2019 01:14 PM
I am refreshing two 3550x switches with new 3750x switches. these swicthes are in two DC and distance between these DC is more then half miles.
correntely 3550 swicthes are connected with Single mode fiber and SC connector.
Can i use 3750x with C3KX-NM-1G= module with GLC-LH-SM= using existing SC connector ?
Amar
05-07-2013 02:10 PM
The C3KX-NM-1G= module take LC type connector. So, yes you can use this module, but your fiber patch cord needs to LC to LC (Single Mode) instead of SC to SC.
You also need to order SFPs.
here is the part number for the SFP
GLC-LH-SM
05-07-2013 02:19 PM
I am using GLC-LH-SM= these are SFP transceiver right..!! do i need any additional HW?
Currently MTRJ being used on the fiber patch panel..
Amar
05-07-2013 02:29 PM
correct
no
If you have to use the MTRJ patch panel to connect these switches together, then your fiber patch cords need to be MTRJ to LC
If you are going directly between the switches then you need LC to LC.
05-14-2013 08:15 AM
i found C3KX-NM-10G= instead of C3KX-NM-1G= in our warehouse,, can i still use GLC-LH-SM= transceiver ? does C3KX-NM-10G= support GLC-LH-SM= transceiver ?
Amar deep
05-14-2013 10:43 AM
No, it does not.
05-14-2013 10:57 AM
So are you saying it doesn't support even if we are using C3KX-NM-10G= for 1 Gig (gig1/1/1 -4) connection..?
Amar
05-14-2013 11:03 AM
No, that is is 10Gig module and you can only use 10Gig SFP with it and not 1Gig.
05-14-2013 11:15 AM
Thanks reza,
Could you please advice which module i should use to connect these 3750x 1 gig port seperated more then half miles.. and which connector type is supported ?
Hoping to use SFP-10G-SR= for single mode LC type connector ..!!
Amar
05-14-2013 11:18 AM
05-14-2013 03:32 PM
One Gig? The SFP you specify, SFP-10G-SR will NOT work. This is a 10 Gbps-only fibre optic module.
If you want a 1 Gbps link and at a distance of half-a-mile, then GLC-LH is what you are looking for.
05-16-2013 06:17 AM
Confused.. Are you saying that i can use GLC-LH-SM with C3Kx-NM-10g for connecting 1 gig link which are half miles away? and LC connector is supported?
Amar deep
05-16-2013 04:17 PM
Amar,
I am saying all your part numbers are incorrect.
You said you want to connect 1 Gbps, right?
So you buy C35X-NM-1G (your initial thread), next you said "Hoping to use SFP-10G-SR= for single mode". This will not work because your 3750X expansion module is only for 1 Gbps.
05-17-2013 05:33 AM
Hi Leo,
May be i canfused you..
let me clear now.. i have below devices in two location seperated by half miles. I need 1 gig fiber connectivity.
location A:
C3750x-24
C3Kx-NM-10g
GLC-LH-SM
LC connector type
location B:
C3750x-24
C3Kx-NM-10g
GLC-LH-SM
LC connector type
Now can anyone confirm above solution will work ? if not can i change sfp part to make it work ?
05-18-2013 02:02 AM
Ok, that will work.
