Connecting 2 locations with 2 lines
Anand Narayana
Level 6
Level 6
on Location A 3750 & on location B3com layer 3 switch, A & B are connected with two 2 Mbps leased line with ethernet output, now i wanted to load balance or i wanted to use a etherchannel kind of thing, so that even if 1 link goes, the other should still be up & running. how do i proceed.
3750------3com ---connected via ISP1
3750------3com ---connected via ISP2 to the same location. it is a point-to-point link.
15 Replies 15
Amit Singh
Anand,
I dont think so that the ISP's will aloow to do port channel the two links. My Idea for this would be to configure all the ports as L3 ports and run two static routes with the same admin distance and the Layer 3 switches will automatically load-balance across the two links.
If you want one link to be active and other to be standby, then use floating static routes and have one default route with higher admin distance added to the switches.
HTH,Please rate if it does.
-amit singh
Hi Amith,
thanks for the reply, as suggested by you i will use two static routes with the same admin distance.
ip route 192.168.1.0 255.255.255.0 gigabit 1/0/1
ip route 192.168.1.0 255.255.255.0 gigabit 1/0/2
this is the command your are referring am i right?
correct me if i am wrong
Yes, You are correct.If you are configuring the links as L3 links, I would suggest you to set the next hop IP of each ISP in the default routes instead of gig interfaces.
HTH,
-amit singh
Thanks Amith,
certainly will do as you suggested, will let you know once i do this test by this evening(IST)
Sure will wait for your feedback on the same :)
Hi Amith,
one of my colleague doesn't agree as what you suggested in configuring the same AD to same destination. he says that which ever command is issued last will be the primary link & only if primart goes he says the other will become active. can you suggest me in this regd.
Hi Anand,
The switch will install both the routes in the routing table for your destination 192.168.1.0 and will show you both the interfaces under the " show ip route " command.If its has 2 paths to the same destination it will try to load-balance on it.
Do you have a spare switch to try the same. Please setup a lab and pass the traffic between the 2 switches and see the traffic on the interface.
Here is the one from my Lab :
The network is two routers connected by parallel serial links.
Cherry#sh runn
Building configuration...
Current configuration : 1557 bytes
hostname Cherry
interface Loopback44
ip address 192.168.200.1 255.255.255.0
interface Serial1/0
ip address 192.168.44.2 255.255.255.252
no fair-queue
interface Serial1/1
ip address 192.168.44.6 255.255.255.252
ip route 192.168.100.0 255.255.255.0 192.168.44.1
ip route 192.168.100.0 255.255.255.0 192.168.44.5
end
* There are two static routes to 192.168.100.0
* which is in the other router.
Cherry#sh ip ro
Codes: C - connected, S - static, I - IGRP, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
i - IS-IS, L1 - IS-IS level-1, L2 - IS-IS level-2, ia - IS-IS inter area
* - candidate default, U - per-user static route, o - ODR
P - periodic downloaded static route
Gateway of last resort is not set
192.168.44.0/30 is subnetted, 2 subnets
C 192.168.44.4 is directly connected, Serial1/1
C 192.168.44.0 is directly connected, Serial1/0
C 192.168.200.0/24 is directly connected, Loopback44
S 192.168.100.0/24 [1/0] via 192.168.44.1
[1/0] via 192.168.44.5
* Both routes appear in the routing table because
* they have equal admin distance and metric.
Cherry#
Cherry#
Cherry#ping 192.168.100.1
Sending 5, 100-byte ICMP Echos to 192.168.100.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 28/31/32 ms
Cherry#
s=192.168.44.2 (local), d=192.168.100.1 (Serial1/0), totlen 100, fragment 0, fo 0, sending
s=192.168.100.1 (Serial1/0), d=192.168.44.2 (Serial1/0), totlen 100, fragment 0, fo 0, rcvd 3
s=192.168.44.6 (local), d=192.168.100.1 (Serial1/1), totlen 100, fragment 0, fo 0, sending
s=192.168.100.1 (Serial1/1), d=192.168.44.6 (Serial1/1), totlen 100, fragment 0, fo 0, rcvd 3
* See how the pings are sent alternately on S1/0 and S1/1. The responses also
* come back on alternate routes because the other router has a similar config.
* This is call equal cost load sharing.
-amit singh
Hi Amith,
i small info required again, with the same AD having to static routes to the same destinations , as u mentioned load balance will happen, but assume in a situation that i hav already connected to the remote end for a telnet or vnc session, now if one of the ISP failz, what will be the case, will the session get closed & do i need to re-open again?
Note: i was assumed that, two request will go via two links simultaneously for accessing telnet or vnc sessions.
Hi Anand,
By default " per-destination" loadbalancing is enabled on the L3 devices. Which means that the traffic from same source to the same destination will always prefer the same link. If you have that situation in this case you will loose you connection to the server and you have re-initiate the connection to the remoe server again.
-amit singh
Hi Amith,
i am sorry, not clear in what you say explain little bit brief?
if i am not wrong, you mean to say that by default it will rely on one link & if that link goes it will never shift automatically to the other link, am i right?
Anand,
Let say that you are trying to reach Host A at Site A to Host B on Site B. You also have ISP1 and Isp2 links betwen the two sites. As "per destination" CEF load balancing is enabled by default, When ou initiate two sessions to the HOST B, they both will use the same ISP lets say ISP1 at the same time. As far as your destination of Host B is same, the router from Site A will always prefer the ISP1 link. and In case the ISP1 link goes down you will loose the connectivity and you have initiate the connection again to the HostB.
If you configure the CEF per-packet load-balancing, then router will try to load-balance on both the avialable links by per-packet behaviour. Incase one of the link fails, you dont have to re-initiate the connection in that case, if the application doesnot time out before the packet reaches the Host B from another link.
Hope I have made it clear enough.
-amit singh
Hi Amith,
can you throw a configuration on this with the CEF, so that i can try & will let know?
Hi Anand,
Unfortunately, Cat3750 does not support h/w CEF per-packet load balancing. h/w load balancing is based on hash of source/destination ip addresses. CEF per-packet load sharing is only supported for packets being switched in software. If the incoming packets have ip option then they'll be switched by 3750 in software and per-packet load balancing should work.
I woul not recommend you to disable the CEF for per-packet load-balancing and software switching might eat up a lot of CPU resources. You have to live only with per-destination load-balancing on 3750.
-amit singh
Hi Amith,
any configuration is there related to this, so that i can go head in testing with this tonight in the network, otherwise i need to plan on some other day.
