06-08-2017 11:16 PM - edited 03-08-2019 10:55 AM
I have 2 cisco switches a SG200-26FP and a SG350XG-26F i have connected both switches via fibre and i am able to connect to all devices connected but i am not able to access the interface on the SG350XG-26F but if i connect the 2 switches via CAT6 cables then i can access the interface any suggestions how i can reach this over the fibre connection
06-08-2017 11:33 PM
what interface are you not being able to reach, the GUI ?
On the SG350XG-26F, under Port Settings --> Port Type, make sure you have selected either 'Combo Ports' or '10G-Fiber-Optics'...
06-08-2017 11:46 PM
Hello
Yes its the GUI i cannot access everything else on my network i can access via the switch
It shows 10G-Fibre-Optics but i do not see an option to change this to combo ports
06-08-2017 11:57 PM
10G-Fibre-Optics is okay, that is the right port setting.
Are you using IP address 192.168.1.254 (the factory default), in your web browser ? Is your system LED flashing continuously ? Make sure the OOB port is connected to your PC, that is the port you need to access the web GUI.
06-09-2017 12:05 AM
Yes connecting to the OOB port works but i wanted to know if there was another way as i want to have mutiple switches connected via fibre to the X350 and be able to reach the interface from any switch
06-09-2017 12:23 AM
that is possible when the device is using a DHCP-assigned IP address or an administrator-configured static IP address. That address must be reachable from within your network.
Check the attached user guide for reference.
http://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbms/350xg/admin_guide/AG_CiscoSwitch_350_550.pdf
