01-30-2013 03:16 PM - edited 03-07-2019 11:25 AM
Hi Guys,
I have been asked to setup some new switches in our LAN.
We have 2x WS-C3560X-48 with the 10Gb SFP C3KX-NM-10G module.
I want to use the 10Gb SFP (with a redundant 1Gb link) between each of the switches.
Below is the configuration what I think I should use. Is this correct?
SWITCH1
int TE1/1
switchport mode trunk
channel-group 1 mode active
int Gi0/48
SWITCH2
int TE1/1
int Gi0/48
We also want to utilise Link Agrrigation for the servers that attach to the switch. Would this config be correct?
port-channel load-balance src-ip
int range x
switchport mode access
switchport access vlan 1 (They are all on the default vlan)
spanning-tree portfast
channel-group x mode active
(Then I would configure the LACP config on the server)
Is there anything I am missing? I would like this to go as smooth as possible.
Any help is appreciated
Jason
01-30-2013 03:20 PM
Won't work.
Rule #1 in Etherchannel. ALL the links need to have the SAME SPEED.
01-30-2013 03:27 PM
Ok Thanks,
So if I remove the Etherchannel on the links between the switches like so. This will work?
SWITCH1
int TE1/1
SWITCH2
int TE1/1
01-30-2013 03:43 PM
Yes, this will work fine.
FYI and as Leo noted:
When deploying portchannel, the ports on both sides need to have the same speed and duplex.
01-30-2013 03:54 PM
Thank you Leo and Reza for your help. This answers my question.
01-30-2013 04:37 PM
Your second question, LACP.
My opinion is to use "ON" instead of "ACTIVE".
01-30-2013 07:21 PM
Thanks, I'll give that a try.
Is there anyway to setup a redundant 1Gb connection between the switches, incase the 10gb module fails?
Preferebly a solution that supports automatic failover?
01-30-2013 07:36 PM
Just put two 1 Gbps in an EtherChannel.
01-30-2013 11:40 PM
If you have only 1 x 10gb port between the 2 switches and you want to use this and have a backup using a 1gb, why not just have both in a RSTP trunk?
02-04-2013 03:33 PM
Hi Andy,
How would I go about creating a RSTP trunk with Gi0/48 and TE1/1 bewteen each switch?
